dynamic ip configuration
CSCO10825585
Community Member
Hello!
I have a Cisco 827 that I it want to use for my connection to Internet in house.
I have tried several configurations but I have not managed to connect to Internet.
I don?t have static ip, my ip is dynamic.
This is my configuration:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname gorka
enable secret xxx
enable password ++++++++!
ip subnet-zero
no ip routing
interface Ethernet0
no ip route-cache
bridge-group 1
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 8/32
encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
ip classless
ip http server
ip pim bidir-enable
snmp-server community public RO
bridge 1 protocol ieee
line con 0
stopbits 1
line vty 0 4
password ++++++++
login
scheduler max-task-time 5000
end
Do I need a dialer?
Thanks.
5 Replies 5
spremkumar
Level 11
Level 11
hi
You can refer the config samples stated in the below link for Cisco 827 routers.
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_configuration_examples_list.html
regds
stephen.stack
Level 9
Level 9
Hope you don't mind if i jump in with some more specific info here.
It appears that you do not have dialer interface setup to negotiate ppp paramaters with you ISP.
Try the config below. you need to get the PVC settings from your ISP and the encapsulation type.
interface ATM0
no ip address
ip route-cache flow
no shut
interface ATM0.1 point-to-point
pvc 8/32
pppoe-client dial-pool-number 1
no shut
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname ISPUSERNAME
ppp chap password ISPPASSWORD
no shut
the ip address negotiated command will give the dialer interface an IP address from you ISP. to check it do a 'sh int dialer 0'.
Load this configuration into your router and watch in dialer 0 to see if it gets an ip address.
Let me know how this goes.
Remember - please rate all posts 🙂
Cheers
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
noticed this in your config:
no ip routing !!!
stephen.stack
Level 9
Level 9
Just noticed another thing thank to the last guy.
enable ip routing
create a static route point all traffic out dialer0
i.e. ip route 0.0.0.0 0.0.0.0 dialer0
also enable nat as follows
Int e0
ip nat inside
dialer 0
ip nat outside
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
you need to do this to allow all PC's/hosts inside your router access to the internet.
Thanks... Pls Rate all posts
Stephen
Hi Stephen!
I am sorry not to have answered before, but I have not seen the response.
At the moment i have this configuration:
version 12.2
no service pad
hostname Router
ip subnet-zero
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
bundle-enable
hold-queue 224 in
pvc 8/32
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname adslppp@telefonicanetpa
ppp chap password 0 adslppp
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip pim bidir-enable
access-list 1 deny any
line con 0
password indartsu99
stopbits 1
line vty 0
access-class 1 in
exec-timeout 120 0
password indartsu99
login
line vty 1 4
password indartsu99
login
end
I have managed to go out to Internet but i can see only a few pages.
To the majority I do not go out.
If I remove the "acces list 1" I do not see any.
That interface affects? Do not I see any access-group in any interface?
Your mtu is different...
Can it be a safety problem?.
Doing a "show in eth0" I see that I have ip.
All interfaces are up.
I can do "ping" on the outside without problems from the pc and from the router.
Thanks.
Javier.
