Dynamic nat regarding reachability
prestigio391
Hello team,
I want provide little tuning of nat statements .
Situation:
host a.a.a goest to -----> x.x.x ---->DNAT to y.y.y (everything works)
BUt in situation when is DNAT y.y.y unrecheable i want change nat statement to :
host a.a.a goest to -----> x.x.x ---->DNAT to z.z.z
Is this possible with ip sla track ? OR EEM scripting is necesary ?
Its funny but i did it exactly the same way few hrs ago So thank you for your answer
balaji.bandi
yes possible, you need to clear NAT table with EEM Script
use below thread for example :
https://community.cisco.com/t5/routing/static-nat-for-two-internet-connect/td-p/3925675
BB
Hello
You can use both ipsla and eem.
Example:
ip sla 1
icmp-echo <to y.y.y > source-interface xxx
ip sla schedule 1 life forever start-time now
track 10 rtr 1 reachability
event manager applet DNAT1_down
event track 10 state down
action 5.0 cli command "enable"
action 5.1 cli command "conf t"
action 5.2 cli command "no ip nat inside source static x.x.x.x y.y.y.y "
action 5.3 cli command "clear ip nat translation inside x.x.x.x y.y.y.y"
action 5.4 cli command "ip nat inside source static x.x.x.x z.z.z.z"
action 5.5 cli command "end"
event manager applet DNAT1_Up
event track 10 state up
action 5.6 cli command "enable"
action 5.7 cli command "conf t"
action 5.8 cli command "no ip nat inside source static x.x.x.x z.z.z.z "
action 5.9 cli command "clear ip nat translation inside x.x.x.x z,z,z,z"
action 6.0 cli command "ip nat inside source static x.x.x.x y.y.y.y"
action 6.1 cli command "end"
Kind Regards
Paul
