04-07-2009 01:40 AM - edited 03-04-2019 04:16 AM
Hi...
I have 2 MB Leased line from R1 To R2.
R1
Inter se 0/0/0
ip add 10.5.4.78 255.255.255.252
no shut
R2
controller E1 1/1
framing NO-CRC4
channel-group 1 timeslots 31 speed 64
interface Serial1/1:1
ip add 10.5.4.77 255.255.255.252
no cdp enable
no shut
When i give remote loop from R1, it get on R2 and vice versa.Also Local loop is getting vice-versa.
I am getting Line protocol Down on Both router.
It's urget..
can some one tell me is it workable like
R1 having link on Modem and R2 having link directly on E1 Controller.
Thanx.....
Solved! Go to Solution.
04-07-2009 03:26 AM
Hi Arjun ,
Check the encapsulation configured for serial interfaces on both the routers..it must be either hdlc or ppp on both the routers.
Please send us " show controller " and show interface output of both the routers.
Did you check the framing, line code and clock source with your provider what type of parameters they configured on their end.
Cheers
MSK 🙂
04-07-2009 03:26 AM
Hi Arjun ,
Cheers
MSK 🙂
04-07-2009 08:17 PM
04-07-2009 04:06 AM
Hello Arjiun,
I think it should be:
controller E1 1/1
framing NO-CRC4
channel-group 1 timeslots 1-31 speed 64
or you want to use only timeslot 31 ?
Hope to help
Giuseppe
04-07-2009 05:49 AM
are you sure that the modeule of wic is supported by the hardware used ?
04-07-2009 09:31 PM
Please check with Service provider if the provisioned link or Circuit is Framed or unframed.
so you have to co-ordinate with the Service provider,
as the VWIC-1MFT-T1/E1 Cards supports
controller E1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
or you if you have G703 controller card
" VWIC2-MFT-G703" or VWIC2-2MFT-G703
controller E1 0/0/0
channel-group 0 unframed
