E1 Sub interface not coming up
Kaushik Ray
Hello
I am having an issue with an E1 Connection where one of the subinterface is up but the other one stays down.
The configs are as follows:
Router A
controller E1 0/1/0
channel-group 0 timeslots 1-28
channel-group 1 timeslots 29-31
interface Multilink2
bandwidth 1984
ip address 192.168.10.1 255.255.255.252
ip tcp header-compression iphc-format
load-interval 30
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
ppp multilink group 2
ip rtp header-compression iphc-format
interface Multilink3
bandwidth 64
ip address 10.10.10.1 255.255.255.252
load-interval 30
ppp multilink
ppp multilink group 3
interface Serial0/1/0:0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0:1
no ip address
encapsulation ppp
ppp multilink
Serial0/1/0:0              unassigned      YES manual up                    up
Serial0/1/0:1              unassigned      YES unset  up                    down
Virtual-Access1            unassigned      NO  TFTP   down                  down
Multilink2                 192.168.10.1    YES NVRAM  up                    up
Multilink3                 10.10.10.1      YES manual down                  down
Router B
controller E1 0/2/0
bandwidth 1984
ip address 192.168.10.2 255.255.255.252
load-interval 30
ppp multilink
bandwidth 64
ip address 10.10.10.2 255.255.255.252
load-interval 30
ppp multilink
interface Serial0/2/0:0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/2/0:1
no ip address
encapsulation ppp
ppp multilink
Serial0/2/0:0              unassigned      YES unset  up                    up
Serial0/2/0:1              unassigned      YES unset  up                    down
Loopback0                  10.183.32.4     YES NVRAM  up                    up
Multilink2                 192.168.10.2    YES NVRAM  up                    up
Multilink3                 10.10.10.2      YES manual down                  down
6 Replies 6
Giuseppe Larosa
Hello Kaushik,
I'm afraid you should use two channel-group numbers like 1 and 2, channel-group 0 is fine when associating all the timeslots to it, or for unframed operation.
I would not use channel-group 0 in this scenario
Hope to help
Giuseppe
Thanks Giuseppe
I changed to following but the issue remains:
Router A
controller E1 0/1/0
channel-group 1 timeslots 1-29
channel-group 2 timeslots 30-31
bandwidth 1984
load-interval 30
ppp multilink
bandwidth 64
load-interval 30
ppp multilink
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0:2
no ip address
encapsulation ppp
ppp multilink
Serial0/1/0:1              unassigned      YES manual up                    up
Serial0/1/0:2              unassigned      YES manual up                    down
Multilink2                 192.168.10.1    YES manual up                    up
Router B
controller E1 0/2/0
bandwidth 1984
load-interval 30
ppp multilink
bandwidth 64
load-interval 30
ppp multilink
no ip address
encapsulation ppp
ppp multilink
interface Serial0/2/0:2
no ip address
encapsulation ppp
ppp multilink
Serial0/2/0:1              unassigned      YES unset  up                    up
Serial0/2/0:2              unassigned      YES unset  up                    down
Flaps a lot
Dec  6 11:15:41.283 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
Dec  6 11:16:03.439 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to up
Dec  6 11:16:03.451 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
Dec  6 11:16:07.471 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to up
Dec  6 11:16:07.483 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
Dec  6 11:16:11.503 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to up
Dec  6 11:16:13.523 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
Dec  6 11:16:17.551 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to up
Dec  6 11:16:19.571 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
Dec  6 11:16:23.599 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to up
Dec  6 11:16:23.611 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:2, changed state to down
When i shut down the Mu3
the serial interface comes up!!
Serial0/2/0:2              unassigned      YES unset  up                    up
Multilink3                 10.10.10.2      YES manual administratively down down
Hello Kaushik,
I see
I hadn't used the multilink bundles the derived serial interfaces se0/2/0:1 and se0/2/0:2 can be used directly as L3 interfaces.
Hope to help
Giuseppe
Thanks Giuseppe
i removed the multilink and set it directly as L3 interfaces and it now looks like it is working.
Many Thanks for all your help with this.
Kaushik
Hi Kaushik
In order to have multiple multilinks beween two routers, you need to configure different authenticated usernames for each bundle.
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080093c1d.shtml
Thank you
Raju
