Routing multicast address 224.0.0.251
jinestrosa
Hello
we would like to know if it's possible to route the multicast address 224.0.0.251 between VLAN?
Thanks for yours feedbacks
Mohamed Sobair
Level 7
Level 7
Yes its possible if you have multicast routing enabled between Vlans and Pim for example.
Mohamed
Giuseppe Larosa
Hello Jose,
short answer no: you cannot route addresses in block 224.0.0.x between different IP subnets they are reserved for link local scope and they cannot be routed, usually a packet with destination 224.0.0.x should also have IP TTL = 1 in IPv4 header.
For this reason for example auto-RP well known MAC addresses are 224.0.1.39 and 224.0.1.40 they need to be able to travel over multiple router hops.
Routing  protocol hello messages use addresses like 224.0.0.X
224.0.0.5-224.0.0.6 is used by OSPF
224.0.0.9 by RIPv2
224.0.0.10 by EIGRP
224.0.0.13 by PIM
and so on these messages are link local confined to the Lan segment where they are generated
Hope to help
Giuseppe
Hi Giuseppe,
I am trying to communicate two vm machines resides in same VLAN over the same multicast address 224.0.0.251. This is an Oracle HeartBeat utility. It works on the same multicast address. Showing me error failed to communicate.
Please advise if I have to configure anything on Nexus 1000v for multicast.
Aman
Mohamed Sobair
Level 7
Level 7
Jose,
Gui is correct, I didnt notice the multicast range you wrote.
The range: 224.0.0.0/24 is all reserved and have link local scope with TTL value of 1.
