E1 to WIC
rajivrajan1
Level 3
Level 3
Hi ,
There is a Channelised E1 output which is from mux . as my controller port is faulty can i connect this outout of e1 ( RJ45) to 2mb modem ( RAD ASM)(using WIC in router) and get the link through ?
Actually i tried it and failed .. is there any suggestions ?
paolo bevilacqua
Can you describe again what is that you want to connect and where ?
shivlu jain
Level 5
Level 5
kindly check the switch setting at modem end.
regards
shivlu jain
rahul0904
If I understand the setup correctly, you will require a RAD convertor modem as the output that you are getting is G.703 which needs to be converted to V.35
The problem is that is not really clear what the OP wants to do.
Cisco routers have G.704/G.704 natively with the right cards and need no converters.
