ISIS
mailaglady2
I have two routers 7206 & 1841 connected point-to-point. But my ISIS is not converging. below are my configs
R7206
interface GigabitEthernet0/2
ip address 192.5.1.1 255.255.255.0
ip router isis
duplex full
speed auto
media-type rj45
no negotiation auto
isis circuit-type level-1
interface Serial6/0
bandwidth 2000000
ip address 165.148.120.2 255.255.255.252
ip router isis
encapsulation ppp
no keepalive
serial restart-delay 0
no fair-queue
router isis
net 20.0001.0000.0000.0000.00
is-type level-1
redistribute connected
R1841
interface FastEthernet0/1
ip address 192.1.1.1 255.255.255.0
ip router isis
speed 100
full-duplex
interface Serial0/1/0
bandwidth 8000000
ip address 165.148.120.1 255.255.255.252
ip router isis
encapsulation ppp
no keepalive
no fair-queue
clock rate 8000000
router isis
net 20.0002.0000.0000.0000.00
is-type level-1
What could be a problem here?
Mohamed Sobair
Level 7
Level 7
The Problem here is that your ISIS is not forming adjacency because they are level-1.
In level-1 ISIS the AREA MUST match, the System-id has to be different.
Looking at your config, the Areas are different and therfore ISIS wont form adjacency and exchange level-1 database.
Mohamed
msobier
your solution worked, my problem was with the area.
baldy
two things I'd try. One is that all the cisco example show the net with an AFI of 47 or 49. I seem to recall having problems using undefined AFI's. My lab is working with the format 47.aaaa.bbbb.cccc.dddd.00
Only other thing that leaps to mind is check your MTU's at each end of the serial.
