Showing results forĀ
Search instead forĀ
Did you mean:Ā
EBGP and DMVPN
MrBeginner
Dear all ,
I would like to ask duplicate question.
I would like to clear eBGP and DMVPN.
May i know can we use eBGP as both of under lay protocol and overlay protocol ?
I mean i will eBGP to peer with ISP and also use again as routing  for DMVPN . May know it will double BGP ? That double usage will be conflict ? because underlay is bgp and overlay is also bgp in Same AS.is it recommend ?
i always see underlay is bgp and overy is EIGRP.
you can use (e)BGP as the only protocol. Have a look at the below sample config (this is for Phase 3):
https://networklessons.com/cisco/ccie-routing-switching/dmvpn-phase-3-bgp-routing/
