EBGP configuration over one router
interfacedy
Hi there are three routers linked together like this: R1---R2---R3. R1 and R3 can ping each other through R2. There is basic ebgp config on R1 and R3 for ebgp connection between R1 and R3. No bgp config is allowed on R2. Now we want to setup ebgp neighbor connection between R1 and 3. What else config is needed for this purpose? Thank you
3 Accepted Solutions
This is homework, isn't it?
If you have a basic BGP config on R1 and R3 (whatever this is), start bei debugging the BGP communication and see if there is any hint in the debug.
Hello
Best practice would be to peer to a lookback interface of both rtrs.
So if you have
static/ igp
connection ( between rtr 1/3 for their respective loopbacks then the following example should work for you,
Note: Do not use default routes on each rtr for reachability  otherwise the bgp peers will not come up.
.example
R1
ip route 2.2.2.2 255.255.255.255 x.x.x.x
router bgp 1
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.2 ebgp-multihop 3
neighbor 2.2.2.2 update-source loopback 0
R2
ip route 1.1.1.1 255.255.255.255 x.x.x.x
router bgp 2
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 ebgp-multihop 3
neighbor 1.1.1.1 update-source loopback 0
Kind Regards
Paul
if this is just for practicing, you can also configure a tunnel between R1 and R3. The configs would look like below:
R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
ip address 172.16.1.1 255.255.255.0
mtu 1476
tunnel source GigabitEthernet0/0/0
tunnel destination 192.168.23.3
interface GigabitEthernet0/0/0
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
router bgp 1
bgp log-neighbor-changes
no synchronization
neighbor 172.16.1.2 remote-as 2
network 1.1.1.1 mask 255.255.255.255
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 192.168.12.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 192.168.23.2 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
R3
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Tunnel0
ip address 172.16.1.2 255.255.255.0
mtu 1476
tunnel destination 192.168.12.1
ip address 192.168.23.3 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
router bgp 2
no synchronization
neighbor 172.16.1.1 remote-as 1
network 3.3.3.3 mask 255.255.255.255
Hello
So if you have
static/ igp
.example
R1
router bgp 1
R2
router bgp 2
Kind Regards
Paul
R1
interface Loopback0
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
router bgp 1
no synchronization
R2
interface Loopback0
duplex auto
speed auto
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
R3
interface Loopback0
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
network 0.0.0.0
router bgp 2
no synchronization
interfacedy
Thank you all for your reply!
