Which EIGRP commands needed to propagate this static route?
MicJameson1
Hello.
In a 3900 router, which EIGRP commands are needed to propagate the below static route?
(Does EIGRP need a new network statement, or a redistribute statement? May you please list the needed config statement(s)?)
#ip route 10.1.128.0  255.255.240.0  172.16.0.5
>>UPDATE<< This will be performed in ASA 5525 and 1120.  I DO NOT need a static route, I only need to insert the route into EIGRP. (I'm sorry for the confusion.)
Thank you.
It depends on how you want to advertise the network. Either the network command or the redistribute static command will work. A couple of caveats though.
Using the network command will advertise the route as an EIGRP internal route with an AD of 90.
Using the redistribute static command it will advertise the route as external with an AD of 170 (make sure you include the metrics in the same line of this command since EIGRP will advertise an infinite metric by default and it wont propagate). If you use this you have a bit more granular control as you can attach
route-map
to this and modify the attributes. You can also just include the one static route you want instead of every static route on the device. You can also apply the metrics within the static route.
Depending on how you want the route to show up in your network is the one you should choose.
Hope that helps
-David
12 Replies 12
balaji.bandi
depends on where you looking to redistribute - but in general you can do as below :
redistribute static metric [bandwidth] [delay] [reliability] [load] [MTU]
BB
ASA 5525, and also ASA 1120.
I will now read your linked literature.
I expect the needed config input is simple, but I have little experience implementing EIGRP.
My updated understanding is that I DO NOT need a static route, I only need to insert the route into EIGRP.
Router-ASA
the static route in Router
so you need to
redistribute the static into EIGRP in Router
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/8606-redist.html#anc17
and for ASA I share good link for EIGRP in ASA.
Thank you for these informative links. I appreciate it.
You are so so welcome.
The link states...
interface GigabitEthernet0/0
description outside interface connected to the Internet
nameif outside
security-level 0
ip address 198.51.100.120 255.255.255.0
This is the static default gateway configuration
route outside 0.0.0.0 0.0.0.0 198.51.100.1 1
___
does "outside" refer to nameif "outside"?
According to the link example, shouldn't the static
default-gateway IP address be 198.51.100.120 ?
Thank you.
does "outside" refer to nameif "outside"? Yes it same nameif
default-gateway
IP address be 198.51.100.12x? if P2P then it should 198.51.100.12x,  but if it Broadcast domain (ASA and other L3 device connect to one SW or more have same VLAN) then it can be any IP wihtin the range of VLAN subnet.
"According to the link example, shouldn't the static
default-gateway
IP address be 198.51.100.120 ? if P2P then it should 198.51.100.120,  but if it Broadcast domain (ASA and other L3 device connect to one SW or more have same VLAN) then it can be any IP within the range of VLAN subnet."
This does not make sense to me. If there are 3 workstations in vlan77-- 10.0.0.1, 10.0.0.2, 10.0.0.3, and the
default gateway
is nameif outside 10.0.0.99. Then it seems to me that ONLY...
 #route outside 0.0.0.0 0.0.0.0 10.0.0.99
1 will work.
What do you say?
First I correct previous comment,
second, the route in FW must end with
next-hop
not IP of OUT interface.
if you have
ASA with OUT IP 10.0.0.99
you can config the default to be
route OUT 0.0.0.0 0.0.0.0 10.0.0.x <<- 10.0.0.x next-hop
A-if P2P
ASA(10.0.0.99)-Router(10.0.0.100)
then it should 10.0.0.100
B- but if it Broadcast domain (ASA and other L3 device connect to one SW or more have same VLAN) then it can be any IP wihtin the range of VLAN subnet.
ASA(10.0.0.99)-SW-Router(10.0.0.51)
ASA(10.0.0.99)-SW-Router(10.0.0.52)
ASA(10.0.0.99)-SW-Router(10.0.0.100)
it can be 10.0.0.51 or 10.0.0.52 or 10.0.0.100
route-map
Hope that helps
-David
Thank you for your informative posts.
