Edge Router to ISP ACL Help
stownsend
Level 2
Level 2
I have one Employee that Cannot access anything at our Corporate HQ Site. If I remove the ACL on the ISP's Incoming Interface they can get through just fine.
Here is the ACL I have defined.  Is there something out of the ordinary that I have going on here?
access-list 110 deny   ip 127.0.0.0 0.255.255.255 any
access-list 110 deny   ip 192.0.2.0 0.0.0.255 any
access-list 110 deny   ip 224.0.0.0 31.255.255.255 any
access-list 110 deny   ip host 255.255.255.255 any
access-list 110 deny   ip host 0.0.0.0 any
access-list 110 deny   ip 10.0.0.0 0.255.255.255 any
access-list 110 deny   ip 172.16.0.0 0.15.255.255 any
access-list 110 deny   ip 192.168.0.0 0.0.255.255 any
access-list 110 deny   ip 0.0.0.0 255.255.255.0 any
access-list 110 deny   tcp any any eq telnet
access-list 110 permit icmp any any echo-reply
access-list 110 permit icmp any any unreachable
access-list 110 permit icmp any any time-exceeded
access-list 110 permit ip any any
Thanks!
johnlloyd_13
Level 9
Level 9
hi,
i don't see any ACE that would hinder your user's IP traffic towards your HQ unless there's a firewall somewhere over your LAN.
maybe you can ask the user to give you a traceroute and see where the traffic drops?
Jigar Dave
Level 3
Level 3
if you are using proxy, have you make sure that he has proxy enabled on his laptop while accessing HQ ?
stownsend
Level 2
Level 2
I feel a bit dumb.   As I waked a co-worker through what each of the lines in the ACL was doing, I found the Offending line that was causing the issue with this user.   Looks like I also forgot to supply his Public IP address.  Its a Comcast Cable modem Customer, nothing fancy, we have several users on ComCast Cable.  his IP address was in a Subnet that was larger than a Class C Address Space. So his IP address ended in a .0
This was in there :
To prevent the Subnet's Network Address from being Spoofed and used to access the Interface for DoS Attacks.   Well if your Subnet is Larger than a Class C Address a A.B.C.0 address is a valid address.
I removed the line and they were able to connect with no issues.
Scott<-
Nice one Scott! Glad you were able to resolve it.
