EEM SCRIPT- HELP. CHECK THE INTERFACE STATUS BEFORE EXECUTING CLI
NAGA1
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 10 interface TenGigabitEthernet0/0/0 line-protocol
track 12 list boolean or
object 1
object 2
event manager session cli username "EEM"
event manager applet SHUT_IF authorization bypass
event track 12 state down
Below commands should not executed if the interface TenGigabitEthernet0/0/0 was already down”. The below commands should work only if the interface is UP.
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface TenGigabitEthernet0/0/0"
action 4.0 cli command "shut"
action 5.0 cli command "end"
the applet below would be a simpler way to accomplish what you want. The applet would run every 60 seconds, you can change that value if needed:
event manager applet INTERFACE_STATUS_DOWN
event timer watchdog time 60
action 2.0 cli command "show interfaces TenGigabitEthernet0/0/0"
action 3.0 string match "*up*" "$_cli_result"
action 4.0 if $_string_result eq "1"
action 5.0 cli command "conf t"
action 6.0 cli command "interface TenGigabitEthernet0/0/0"
action 7.0 cli command "shut"
action 8.0 end
