EHWIC-VA-DSL-B VDSL2 general question
I have to set up a VDSL2 connection (G.993.2) using an EHWIC-VA-DSL-B adapter on a 2911 ISR G2 router.
Could someone please explain why this is beeing configured using the Ethernet - Interface (in my case ethernet0/0/0) instead
of the ATM interface (beeing used in "old school" ADSL installations)?
Is there really Ethernet running between the Controller and the DSLAM? If so, why do we need a specific Controller for it?
I did not find a document which explains this in more detail.
Example:
interface Ethernet0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip flow ingress
no ip route-cache
load-interval 30
interface Ethernet0/0/0.7
description VDSL2 Internet Connection German Telekom - VLAN 7 tagged
encapsulation dot1Q 7
no ip route-cache
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
description Internet
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1412
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname ***removed***
ppp chap password ***removed***
ppp pap sent-username ***removed***
ppp ipcp dns request
no cdp enable
Heinz
Ethernet can work on many different medias.
In this case layer 2 is Ethernet, layer 1 is VDSL2.
6 Replies 6
paolo bevilacqua
Correct, VDSL2 is Ethernet First Mile technology, and there is no more ATM.
Note your adjust-mss value is wrong, should be 1452. Also, ppoe enable and dialer-group are not needed, and virtual reassembly should be disabled.
But isn´t the maximum cable length for Ethernet over copper just 100 meters?
Ok, understood.
Thank you!
Heinz
Hi Paolo,
why should virtual reassembly be disabled?
Heinz
Because is deleterious.
Thank you for the nice rating and good luck!
