EHWICs
Dinesh Murthy
Iam having a cisco 3945 router, needs to configure wan links in that. kindly suggest a network module which can support wan configuration and it should be in TJ45,because the service providers are providing connections through RJ45 only.
Whether HWIC-D-9ESW can support wan routing function ?
8 Replies 8
paolo bevilacqua
Your router comes with three ethernet interfaces already, nothing else is needed.
Thanks Paolo, But i need to terminiate 8 wan connections in this router. Could you please advice which module willl support my requirement.
You can use a switch and VLAN interfaces.
can SM-ES3-16-P used instead of HWIC-2FE ?
Dinesh Murthy
As answered above, use an external switch.
Hi Paolo,
    So i have to create a sub interfaces in the router and assign each wan location ip addres in that, that should be terminated in a switch configure vlans and map according to that. is that right ? Kindly suggest the below sample setup and config.
HubRouer0#
HubRouer0#sh run
Building configuration...
hostname HubRouer0
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 10
ip address 172.16.63.5 255.255.255.252
interface GigabitEthernet0/0.2
encapsulation dot1Q 20
ip address 172.17.63.5 255.255.255.252
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 10
network 172.16.63.4 0.0.0.3
network 172.17.63.4 0.0.0.3
auto-summary
ip classless
end
BranchRouter1#sh run
Current configuration : 572 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname BranchRouter1
interface FastEthernet0/0
ip address 172.16.63.6 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 10
auto-summary
ip classless
end
BranchRouter2#sh run
version 12.4
hostname BranchRouter2
ip address 172.17.63.6 255.255.255.252
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 10
auto-summary
ip classless
end
Switch#sh run
Current configuration : 1182 bytes
version 12.2
hostname Switch
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 10
interface FastEthernet0/3
switchport access vlan 20
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip address
interface Vlan20
no ip address
end
Something like that. Best it that you engage a proven network engineer to do things.
