Eigrp 10 a Router 3810 and two Frame Relay Circuits
FBARRERAR
Hi, i´m installing a router 3810 with to serials interfaces which are using a point to point frame relay circuits each one, my routing protocol is RIP and i will change to Eigrp 10, anyone know how can control that only the HTTP traficc acrooss to the Serial 1, and if exist a tool to view in graphically this consumption?
If i´m using Eigrp and i need use a Point to point frame relay configuratión, ¿what i should config the protocol to use the maxium performance, regarding that i´ma usin two circuits?
thisisshanky
Level 11
Level 11
You can use an access-list to permit only http traffic across the link.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Ok, so the router will use the other link to send web traffic be cause it permit outgoing traffic? do you know how show o see the comsumit in each link?
fabian
