03-29-2005 02:06 AM - edited 03-03-2019 09:09 AM
I have a WIC-1ADSL-DG card that I am trying to install on a 1751. The router detects that there is a WIC installed, but can not recognize what it is. The router is currently running 12.3(13) (c1700-k9o3sy7-mz.123-13.bin).
I know that the Slot is working as I have used a single port Ethernet WIC without problems.
I have tried:
- 2 different WIC-1ADSL-DG cards (same result)
- Both Slot 0 & Slot 1 (same result)
- Multiple IOS versions:
- c1700-advsecurityk9-mz.123-13.bin (same result)
- c1700-k9o3sy7-mz.123-13.bin (same result)
I was under the impression that all I would need to use was an IOS that explicitly stated that it contained the ADSL feature set (eg, IP/ADSL PLUS) or that contained 'y7' in the IOS file name.
Has anyone else had similar troubles?
Antony
Solved! Go to Solution.
03-29-2005 03:37 AM
Hardware not recognized is mainly caused by the application of an incorrect IOS image.
When I checked the following URL:
http://www.cisco.com/warp/public/cc/pd/rt/1700/prodlit/17ad_ds.pdf
it seems to me that you might need IOS 12.3T instead of the main line. Please check the part about software support to see what I mean. If you are able to get this type of image, it might be worth the try.
Leo
03-29-2005 02:08 AM
Forgot to add, if I do a Show Diag, here is what I get:
WIC/VIC Slot 0:
Unknown
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 1.0
PCB Serial Number : **********
Part Number : 73-8433-03
Board Revision : C0
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1ADSL-DG
Top Assy. Part Number : 800-21970-01
CLEI Code : IP5IJBECAA
03-29-2005 03:37 AM
Leo
03-29-2005 05:49 AM
Here is the result of dynamic configuration tool...
CISCO1751
10/100 Modular Router w/ 3 slots, IOS IP, 32F/64D
S17C7P-12311T
Cisco 1700 IOS IP/ADSL PLUS
WIC-1ADSL-DG
1-port ADSLoPOTS WIC with Dying Gasp
WIC-1ADSL-I-DG
1-port ADSLoISDN Wan Interface Card
As you can see that 12.3T series IOS with IP/ADSL Plus feature set, WIC-1ADSL-DG is recognised by the router. Please check your DRAM and flash requirements in th case of lack of DRAM and flash to run this new IOS. Also you may run special releases, suck as the ones start witk X. "XY","XW","XQ" and etc...
Baris.
03-29-2005 03:25 PM
Hi Guys,
Thanks for your help. I will try out a T release and let you know how I go ...
Antony
03-29-2005 03:50 PM
Arggghh!!! It worked!
Here is the IOS I used:
1751 ADVANCED SECURITY 12.3.11T3
c1700-advsecurityk9-mz.123-11.T3.bin
Am I the only one who finds it strange that a feature set advertised as ADSL (eg, IP/ADSL PLUS ... but not a T release) doesn't actually support ADSL WICs???
