EIGRP config
impulsion84
Frequent Visitor
Frequent Visitor
Hi people,
Please don't hang me but i am lacking some skills and i would need your help.
Router 1 and Router 2 in the main site have this class mapped from a secondary site:
D        10.10.24.0/21 [90/54277120] via 10.1.255.10, 2d18h, Tunnel50
                       [90/54277120] via 10.1.255.3, 2d18h, Tunnel50
Routing entry for 10.10.24.0/21
  Known via "eigrp 1", distance 90, metric 54277120, precedence routine (0), type internal
  Redistributing via eigrp 1, ospf 1
  Advertised by ospf 1 subnets route-map EIGRP_StaticRedistribution
  Last update from 10.1.255.10 on Tunnel50, 2d18h ago
  Routing Descriptor Blocks:
    10.1.255.10, from 10.1.255.10, 2d18h ago, via Tunnel50
      Route metric is 54277120, traffic share count is 1
      Total delay is 6010 microseconds, minimum bandwidth is 100 Kbit
      Reliability 255/255, minimum MTU 1400 bytes
      Loading 15/255, Hops 2
  * 10.1.255.3, from 10.1.255.3, 2d18h ago, via Tunnel50
      Loading 1/255, Hops 2
P 10.10.24.0/21, 2 successors, FD is 6947471360
        via 10.1.255.3 (6947471360/328990720), Tunnel50
        via 10.1.255.10 (6947471360/328990720), Tunnel50
        via 10.1.253.3 (7078543360/328990720), Tunnel60
        via 10.1.253.10 (7078543360/328990720), Tunnel60
        via 10.1.252.10 (7144079360/328990720), Tunnel61
        via 10.1.252.3 (7144079360/328990720), Tunnel61
        via 10.1.254.10 (7013007360/328990720), Tunnel51
        via 10.1.254.3 (7013007360/328990720), Tunnel51
I do not know how to add another class like: 10.10.40.0 to the routing table for eigrp 1 on Tunnel50.
Settings on the secondary site: D 10.10.24.0/21 [90/2570240] via 192.168.51.2, 3d02h, Port-channel1.502
So once done on the main routers, i will have to do it on the secondary routers also.
Short story, i've created a new VLAN 42 for 10.10.40.0 and i need it to talk to the main site. The ACL are configured on the main switches on the secondary site and that's fine, i can ping stuff around this site, but obviously not working form the main site since the ip's are not in the routing tables.
Thank you
10 Replies 10
 You mean, router 1 and 2 in the main side is receiving this network 10.10.24.0/21 from the secondary site via Tunnel50 using EIGRP?
Now, you create a new vlan 42 on the secondary side with IP address 10.10.40.0and you need this network to also be advertised to Main side?
 You must have EIGRP running on the Secondary's side Router, right?
You need to add this network on the  EIGRP process
router eigrp x
 netwrok 10.10.40.0  <wild card mask>
impulsion84
Frequent Visitor
Frequent Visitor
Yes, both routers from the main site are receiving the network from the secondary site via Tunel50 using EIGRP
Both routers at the secondary site:
192.168.51.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.51.0/29 is directly connected, Port-channel1.502
L 192.168.51.1/32 is directly connected, Port-channel1.502
So yes, i would need to add 10.10.40.0 to EIGRP on the secondary routers first
This dmvpn dual hub?
If yes then you can add delay in branch site and this make prefix learn from one one hub.
Yes.
impulsion84
Frequent Visitor
Frequent Visitor
Just tried this:
R01#show running-config | section ospf
 ip ospf mtu-ignore
 ip ospf network broadcast
 ip ospf priority 0
 ip ospf mtu-ignore
 ip ospf cost 10
 ip ospf priority 0
 ip ospf mtu-ignore
 ip ospf cost 20
 ip ospf priority 0
 ip ospf mtu-ignore
 ip ospf cost 30
 ip ospf priority 0
 ip ospf mtu-ignore
 ip ospf cost 40
router ospf 1
 router-id 192.168.254.245
 area 10.10.24.0 nssa no-summary
 area 10.10.24.0 range 10.10.24.0 255.255.248.0
 redistribute static metric-type 1 route-map OSPF_StaticRedistribution
 passive-interface default
 network 10.1.252.0 0.0.3.255 area 0
 network 192.168.51.0 0.0.0.7 area 10.10.24.0
 network 192.168.254.245 0.0.0.0 area 0
 default-information originate
R01#show route-map
route-map EIGRP_StaticRedistribution, permit, sequence 10
  Match clauses:
    ip address (access-lists): 11
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map OSPF_StaticRedistribution, permit, sequence 10
  Match clauses:
    ip address (access-lists): 10
  Set clauses:
R01#show access-list 10
Standard IP access list 10
10 permit 10.0.0.0, wildcard bits 0.255.255.255
20 permit 172.16.0.0, wildcard bits 0.0.255.255
R01#show access-list 11
Standard IP access list 11
10 permit 0.0.0.0 (85 matches)
20 permit 10.10.0.0, wildcard bits 0.0.255.255
Tried also:
  1. router ospf 1 > network 10.10.24.0 range 10.10.40.0 255.255.255.0
     and got this error:
R01(config)#router ospf 1
R01(config-router)#$10.24.0 range 10.10.40.0 255.255.255.0
% Invalid input detected at '^' marker.
Not sure about this range statement, never used.
router ospf
 network 10.10.40.0  0.0.0.255
That's how we add a network to an OSPF process.
router OSPF x
area x range x.x.x.x mask <<- this only apply to ABR router
summary-address <<- this apply to ASBR, I think here you have ASBR since you run eigrp/ospf in same router.
BUT the your issue is not clear to me
thanks
MHM
impulsion84
Frequent Visitor
Frequent Visitor
The site where i have the new VLAN:
Layer 3 switch with all the ACL's configured:
S01>ping 10.10.40.13
Sending 5, 100-byte ICMP Echos to 10.10.40.13, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R01>ping 10.10.40.13
Success rate is 0 percent (0/5)
R01 and R02 can't talk to the new VLAN. Long story short.
You are not providing enough information. I dont even know if this network should be advertised on the OSPF or EIGRP, and not sure why you do have both protocols runnning at the same time.
 For further help I would need the show run from the devices involved and if not ask too much, a simple network diagram.
friend It short story but I hope it have happy ending
the R1 and R2 config with tunnel 50,
so it represent two layer OVERLAYER and UNDERLAYER
UNDERLAYER is the tunnel source and OVERLAYER is tunnel itself
we you ping from SW the SW use OVERLAYER only so it success
we you ping from R only you need to specify the source of your ping it must IP in OVERLAYER which I prefer be the tunnel IP.
