eigrp hub and spoke question
pamirian76
hi,
I,m working with gns3 to setup a test environment.
3 routers, 2 of them are hubs and the last one is a spoke.
with the 2 routers I'm just giving a default route to my spoke which is also just a stub router. then the stub is simply pushing to the hubs a summary.
now what I would like to do with the hubs is decide if on the spoke tunnel0 or tunnel1 gets used. right now they both have the same priority but I would like to be able with the hubs to make that decision.
so basically on hub I change something and it makes spoke #24 use tunnel 0 to hub 1 instead of tunnel 1 to hub 2.
hope I,m clear
also if possible please give me an example.
thanks.
dslice
###ds How are sending the default from hub to spoke? Summaries? Redistributed locally? Propagated from elsewhere?
Lee Shouse
Have you tried changing the delay on your tunnel interfaces to make one route look better than the other?
