WAN Connection timeout frequently on Cisco 1812
tim1103113
I am using DHCP ISP , but the connection only last for 20 mins exactly and then it will automatically disconnected. Every time I reset the WAN port ,
service back to normal for another 20 mins ><
The are no log or any error message when connection timeout. the status of the WAN port is normal "Up Up".
I have tried this config on another ISP and everything work just fine !!!!!!!
Can anyone suggest what should I test now ? Certain keepalive command doesn't help at all.
Fiber converter -------> Cisco 1812 (FastEthernet1) --------->LAN
Router#sh run
Building configuration...
Current configuration : 3205 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging buffered 65565 debugging
no aaa new-model
resource policy
clock timezone GMT 8
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.50
ip dhcp pool HomeDevice
import all
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
default-router 192.168.1.1
lease infinite
ip name-server 8.8.8.8
ip name-server 8.8.4.4
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
username timtoa password 7 XXXXXXXXX
interface FastEthernet0
ip address dhcp
shutdown
interface FastEthernet1
description HKBN
ip address dhcp
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
no cdp enable
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Virtual-Template1
ip unnumbered FastEthernet1
peer default ip address pool PPTP-Pool
no keepalive
ppp encrypt mppe 128
ppp authentication ms-chap ms-chap-v2
interface Vlan1
ip nat inside
ip local pool PPTP-Pool 192.168.1.200 192.168.1.210
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 10 interface FastEthernet1 overload
ip nat inside source static tcp 192.168.1.4 3392 interface FastEthernet1 3392
ip nat inside source static tcp 192.168.1.3 3391 interface FastEthernet1 3391
ip nat inside source static tcp 192.168.1.2 3390 interface FastEthernet1 3390
ip nat inside source static tcp 192.168.1.50 443 interface FastEthernet1 443
ip nat inside source static tcp 192.168.1.50 902 interface FastEthernet1 902
ip nat inside source static tcp 192.168.1.50 903 interface FastEthernet1 903
access-list 10 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
logging synchronous
login
line aux 0
line vty 0 4
login
ntp clock-period 17180152
ntp update-calendar
ntp server 194.177.210.54
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Router#sh dhcp lease
Temp IP addr: 203.XX.217.28 for peer on Interface: FastEthernet1
Temp sub net mask: 255.255.255.192
DHCP Lease server: 203.XX.96.154, state: 3 Bound
DHCP transaction id: 2478
Lease: 15203 secs, Renewal: 7601 secs, Rebind: 13302 secs
Temp default-gateway addr: 203.XX.217.1
Next timer fires after: 01:49:33
Retry count: 0 Client-ID: cisco-c47d.4fe5.2df3-Fa1
Client-ID hex dump: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hostname: Router
paolo bevilacqua
Update IOS and check again.
