Eigrp metric calculations
feroz syed
Level 3
Level 3
Hi.
here is my eigrp topology details. how eigrp get this fd distance, i try to solve this by using famous formula but i didn't get this 156160 value.
R1#sh ip route 1.1.1.1
Routing entry for 1.1.1.1/32
  Known via "eigrp 1", distance 90, metric 156160, type internal
  Redistributing via eigrp 1
  Last update from 172.16.23.2 on FastEthernet1/1, 05:52:13 ago
  Routing Descriptor Blocks:
  * 192.168.1.2, from 192.168.1.2, 05:52:13 ago, via FastEthernet1/0
      Route metric is 156160, traffic share count is 1
      Total delay is 5100 microseconds, minimum bandwidth is 100000 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
      Loading 1/255, Hops 1
    172.16.23.2, from 172.16.23.2, 05:52:13 ago, via FastEthernet1/1
R1#
P 2.2.2.2/32, 2 successors, FD is 156160
        via 172.16.23.2 (156160/128256), FastEthernet1/1
        via 192.168.1.2 (156160/128256), FastEthernet1/0
R1#sh int fa 1/0 | i BW
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
R2#sh int fa 1/0 | i BW
R2#sh int loopback 0 | i BW
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec
my calculations
min BW = 100000
Dly = 100+100+5000 = 5200
26931200
Peter Paluch
So let's see:
By default, K1=K3=1, so BW and DLY are taken into account.
Metric = (K1* (10^7 / BW) + K3 * DLY/10) * 256 = (10^7 / 100000 + 510) * 256 = 610 * 256 = 156160
Remember that the metric formula uses tens of microseconds as the delay factor in its computation.
Best regards,
Peter
13 Replies 13
Peter Paluch
So let's see:
Best regards,
Peter
i saw one article they mention to calculate all link delay,so from r1 to r2 and r2 from loop delay
min BW = 100000
Dly = 100(fa1/0)+100(fa1/0)+5000(loop0) = 5200
256*[10000000 / 100000] + [100+100+5000] /10
256[100]+[5200] /10
135680
You are adding an extra delay, you should only be concerned with the exit interfaces.
So i can calculate only from r1  prespective right ?
Metric = 256*[10^7/100000] + [100+100+5000]/10
256*[100]+[5200] /10
256*5300/10
135680
Yes, compute the metric just from R1's perspective.
Metric = 256 * [10^7 / 100000] + 256 * [100 + 5000] / 10 = 256 * 100 + 256 * 510 = 256 * (100+510) = 256*610 = 156160
Best regards,
Peter
Understood. but actually tha interface delay is DLY 100 usec from r1 view,
fastEthernet1/0 is up, line protocol is up
  Hardware is i82543 (Livengood), address is ca00.14f4.001c (bia ca00.14f4.001c)
  Internet address is 192.168.1.1/24
In usecs, yes, but the metric formula needs tens of usecs. That is why I wrote 256 * [100 + 5000] / 10 in my computation in the previous response.
Best regards,
Peter
sorry didn't understand this
tens of usecs
you mean 100^10 ?
tens of usecs
you mean 100^10 ?
No. The delay on interfaces is expressed in microseconds, e.g. DLY 100 usec means that the delay is 100 microseconds. However, the metric formula needs the delay to be expressed in different units. A single delay unit in the metric formula corresponds to 10 microseconds. Two units would correspond to 20 microseconds. Five units would correspond to 50 microseconds, and 10 units would correspond to 100 microseconds. In general, N delay units correspond to 10*N microseconds, or vice versa, if you have M microseconds, they constitute M/10 units used by the metric formula
Best regards,
Peter
How it change from 100usec to 5100 microsecond ? in formula
Metric = 256*[10^7/BW(min) in Kbps] + [sum of delay in usec/10]
Metric = 256*[10000000/100000(min) in Kbps] + [100usec/10]   <<<< it should be like this
      Loading 1/255, Hops
Because you take the sum of delays in microseconds and then divide them by 10. R1->R2 is 100 microseconds, R2->Lo0 is 5000 microseconds. The sum is 5100 microseconds, or 5100/10=510 units for the metric formula.
Best regards,
Peter
Big thanks for your continues reply and  thanks for not scold me
You are counting the delay on the link between R1 and R2 twice - that is the fault in the computation. When R1 needs to reach R2, it goes over a link that has - from its own viewpoint - a delay of 100 usec. R2's delay on its interface would be relevant for the opposite direction of communication.
Best regards,
Peter
