EIGRP Neighbor flapping between Core's on VLAN 48
Adam Coombs
Hello I am looking for help with this problem i am having.  6513 vlan48 connects to 3750-e switch
I can ping each side of that vlan ip address successfully
traceroute the ip address find
I can ping each side using the source ping option
ping ip 10.200.0.13 source vlan 48 works fine
I have check each port to look for any inputs errors, crc,frame,overrun,ignored etc... all are zero
The intefaces are not passive
This the logging information from the 6513 switch
Sep 17 14:45:05: EIGRP: Packet from ourselves ignored
Sep 17 14:45:10: EIGRP: Packet from ourselves ignored
Sep 17 14:45:16: EIGRP: Packet from ourselves ignored
Sep 17 14:45:19: EIGRP: Packet from ourselves ignored
Sep 17 14:45:25: EIGRP: Packet from ourselves ignored
Sep 17 14:45:28: EIGRP: Packet from ourselves ignored
Sep 17 14:45:32: EIGRP: Packet from ourselves ignored
Sep 17 14:45:38: EIGRP: Packet from ourselves ignored
Sep 17 14:45:43: EIGRP: Packet from ourselves ignored
Sep 17 14:45:47: EIGRP: Packet from ourselves ignored
Sep 17 14:45:50: EIGRP: Packet from ourselves ignored
Sep 17 14:45:56: EIGRP: Packet from ourselves ignored
Sep 17 14:46:01: EIGRP: Packet from ourselves ignored
Sep 17 14:46:04: EIGRP: Packet from ourselves ignored
Sep 17 14:46:10: EIGRP: Packet from ourselves ignored
Sep 17 14:46:13: EIGRP: Packet from ourselves ignored
Sep 17 14:46:18: EIGRP: Packet from ourselves ignored
Sep 17 14:46:23: EIGRP: Retransmission retry limit exceeded
Sep 17 14:46:23: EIGRP: Holdtime expired
Sep 17 14:46:23.237 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 500: Neighbor 10.200.0.13 (Vlan48) is down: retry limit exceeded
Sep 17 14:46:23: EIGRP: Neighbor 10.200.0.13 went down on Vlan48
Sep 17 14:46:24: EIGRP: Packet from ourselves ignored
Sep 17 14:46:27: EIGRP: New peer 10.200.0.13
Sep 17 14:46:27.397 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 500: Neighbor 10.200.0.13 (Vlan48) is up: new adjacency
show ip eigrp interfaces
IP-EIGRP interfaces for process 500
                        Xmit Queue   Mean   Pacing Time   Multicast    Pending
Interface        Peers  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Vl48               1        0/0         0       0/1           50          63
6513 has a loopback address
3750e does not have a loopback address
I am sure there is more i need to give but I cant think of anything right now please i will provide
2 Accepted Solutions
rfalconer.sffcu
Level 3
Level 3
Packet from ourselves ignored is probably coming from your loopback address. Do you need the no passive-interface Loopback0 in there for some reason?
What is your loopback0 specifically doing? Loopbacks are typically used for routing and management but I'm curious if your loopback is actually doing these things.
38 Replies 38
John Blakley
Can you post the config from both switches?
HTH,
John
HTH, John *** Please rate all useful posts ***
Which part of the config you need to see because the 6513 config is really long and 3750e config is not bad?
I should have explained myself better. We only need to see the eigrp section and possibly the "show ip eigrp neigh"
HTH,
John
From the 6513
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-47,49-4094 priority 8192
spanning-tree vlan 48 priority 4096
router eigrp 500
redistribute static
passive-interface default
no passive-interface Vlan48
network 10.200.0.0 0.0.0.3
network 10.200.0.12 0.0.0.3
distribute-list EIGRP_DL_CORE2 out Vlan48
no auto-summary
show ip eigrp neighbors
IP-EIGRP neighbors for process 500
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.200.0.13             Vl48              10 00:00:42    1  5000  2  0
4   172.16.             Vl23              12 2w5d        8   200  0  1056
2   172.16.            Vl23              10 6w5d        1   200  0  3628
1   172.16.            Vl23              10 6w5d        1   200  0  2880
6   10.200.0.1              Vl50              12 29w3d       6   300  0  4220
3   172.16.           Vl23              10 29w3d       6   200  0  4225
From the 3750e
spanning-tree portfast default
spanning-tree etherchannel guard misconfig
no spanning-tree vlan 214
spanning-tree vlan 48 priority 8192
router eigrp 500
distribute-list EIGRP_DL_CORE3 out Vlan48
EIGRP-IPv4 Neighbors for AS(500)
                                            (sec)         (ms)       Cnt Num
0   10.200.0.10             Vl47              13 8w5d        3   200  0  4226
I told forgot about that show ip eigrp neighbors command
Still need help fixing that
Thank you
From the looks of the log, it looks like the hello packet is being reflected back somehow. Can you post the route map for the distribute-list? From the looks of it, you don't currently have an adjacency correct?
HTH,
John
Well this project was given to me yesterday the previous network engineer was working on it, but no helpful notes.
When I show route-map on the 3750e nothing, on the 6513 it shows route-map to our F5 device
What is the command to enter to get exactly what you are looking for ?
Sorry i have not said this sooner thank you for helping with this problem.
Can you post this acl from the two switches?
EIGRP_DL_CORE3
EIGRP_DL_CORE2
And you're welcome! I hope we can get it working for you
HTH,
John
Here you go I thought this is what you wanted, i took at the routes that i know that are nothing to do with this
I would like to get this fixed and learn from it so if i see this on another network i can fixed and refer people to here for great help.
6513
ip access-list standard EIGRP_DL_CORE2
permit 0.0.0.0
permit 172.16.255.3
permit 172.16.255.2
permit 172.16.255.1
permit 172.16.255.4
permit 10.200.0.0 0.0.0.3
permit 10.200.0.4 0.0.0.3
permit 10.200.0.8 0.0.0.3
permit 10.200.0.12 0.0.0.3
permit 10.1.6.0 0.0.0.255
permit 10.20.0.0 0.1.255.255
permit 10.100.6.0 0.0.1.255
permit 172.16.1.0 0.0.0.255
permit 172.16.2.0 0.0.0.255
permit 172.16.3.0 0.0.0.255
deny   any
from the 3750e
ip access-list standard EIGRP_DL_CORE3
permit 0.0.0.0
permit 172.16.255.3
permit 172.16.255.2
permit 172.16.255.1
permit 172.16.255.4
permit 172.16.5.0 0.0.0.255
permit 10.1.0.0 0.0.3.255
permit 10.1.4.0 0.0.1.255
permit 10.2.0.0 0.0.255.255
permit 10.3.0.0 0.0.255.255
permit 172.16.0.32 0.0.0.15
deny   any
If you see something that should be there asked i will send it
Thank you again for contiuning help me with this problem
Adam,
Robert mentioned it earlier, but it didn't dawn on me until now. I'd recommend you put your loopback interface back to passive. This may very well fix your issue. You're receiving the packet back to yourself on this interface I believe. Test that and let us know...
Thanks!
HTH,
John
Well, I will try to put the loopback into passive on the 6513 i have to schedule a maintence window for this.
6513 has the loopback0 but the 3750e does not have a loopback
Question, on the other 6513 we have here that connects to 3750e on a different vlan is not showing flapping and the loopback0 is set the same as the other 6513 that is flapping, how can i make sure that the other 6513 is not flapping to?
Thank you for keep helping me with this problem !!!
"and the loopback0 is set the same as the other 6513 that is flapping,"
This may be part of the problem....I'm going to lab this up. Are you using the loopbacks as anycast addresses by chance? The loopback interface isn't used as a source (usually) and doesn't need to be in non-passive in order to be advertised. The only thing that non-passive does is allow for hellos to be sent out of the interface. If you're advertising the loopback into eigrp, it will still work if you put the loopback in passive.
Are the loopback interfaces /32 or a different mask?
HTH,
John
Adam,
I don't get the same result with two loopbacks, so I'm not sure that's your issue either. Do you have a physical loop anywhere, even if on purpose? You should still try to put your interface in passive. Can you post the interface configurating? sh run int lo
HTH,
John
loopback0 from the flapping 6513
interface Loopback0
ip address 172.16.255.2 255.255.255.255
end
loopback0 from no flapping 6513
interface Loopback0
ip address 172.16.255.1 255.255.255.255
end
These loopback address are used alot in the ACL lines groups
you can see there are in the
EIGRP_DL_CORE2 and 3 lists
Adam,
Is it not possible that the 3750e is on the wrong vlan connecting to the 6500?
                                            (sec)         (ms)       Cnt Num
Tony
