09-17-2013 01:21 PM - edited 03-04-2019 09:04 PM
Hello I am looking for help with this problem i am having. 6513 vlan48 connects to 3750-e switch
I can ping each side of that vlan ip address successfully
traceroute the ip address find
I can ping each side using the source ping option
ping ip 10.200.0.13 source vlan 48 works fine
I have check each port to look for any inputs errors, crc,frame,overrun,ignored etc... all are zero
The intefaces are not passive
This the logging information from the 6513 switch
Sep 17 14:45:05: EIGRP: Packet from ourselves ignored
Sep 17 14:45:10: EIGRP: Packet from ourselves ignored
Sep 17 14:45:16: EIGRP: Packet from ourselves ignored
Sep 17 14:45:19: EIGRP: Packet from ourselves ignored
Sep 17 14:45:25: EIGRP: Packet from ourselves ignored
Sep 17 14:45:28: EIGRP: Packet from ourselves ignored
Sep 17 14:45:32: EIGRP: Packet from ourselves ignored
Sep 17 14:45:38: EIGRP: Packet from ourselves ignored
Sep 17 14:45:43: EIGRP: Packet from ourselves ignored
Sep 17 14:45:47: EIGRP: Packet from ourselves ignored
Sep 17 14:45:50: EIGRP: Packet from ourselves ignored
Sep 17 14:45:56: EIGRP: Packet from ourselves ignored
Sep 17 14:46:01: EIGRP: Packet from ourselves ignored
Sep 17 14:46:04: EIGRP: Packet from ourselves ignored
Sep 17 14:46:10: EIGRP: Packet from ourselves ignored
Sep 17 14:46:13: EIGRP: Packet from ourselves ignored
Sep 17 14:46:18: EIGRP: Packet from ourselves ignored
Sep 17 14:46:23: EIGRP: Retransmission retry limit exceeded
Sep 17 14:46:23: EIGRP: Holdtime expired
Sep 17 14:46:23.237 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 500: Neighbor 10.200.0.13 (Vlan48) is down: retry limit exceeded
Sep 17 14:46:23: EIGRP: Neighbor 10.200.0.13 went down on Vlan48
Sep 17 14:46:24: EIGRP: Packet from ourselves ignored
Sep 17 14:46:27: EIGRP: New peer 10.200.0.13
Sep 17 14:46:27.397 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 500: Neighbor 10.200.0.13 (Vlan48) is up: new adjacency
show ip eigrp interfaces
IP-EIGRP interfaces for process 500
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Vl48 1 0/0 0 0/1 50 63
6513 has a loopback address
3750e does not have a loopback address
I am sure there is more i need to give but I cant think of anything right now please i will provide
Solved! Go to Solution.
09-18-2013 09:22 AM
Packet from ourselves ignored is probably coming from your loopback address. Do you need the no passive-interface Loopback0 in there for some reason?
09-18-2013 10:51 AM
Well the loopback0 that helps with routing and and testing from what i know about it.
09-18-2013 04:59 PM
What is your loopback0 specifically doing? Loopbacks are typically used for routing and management but I'm curious if your loopback is actually doing these things.
09-19-2013 06:08 AM
Well from what i know and see about the loopback setting are for routing and management. Robert how can i test this to make sure the loopback is working correctly besides ping the loopback interface from any switch?
Thank you for your help as well Robert
09-19-2013 07:32 AM
If the loopback is created, it should be doing what is needed. As John said, it shouldn't matter to make that passive since passive just stops eigrp hellos. The loopback interfaces don't need to be included in eigrp neighbor relationships. Even if you make it passive, it won't stop other things from working.
John also asked about loops. How many connections are there between the 3 switches? Have you looked at sh cdp neighbor to see where you have connections between the switches?
Also, have you done any debugs on eigrp?
09-19-2013 08:02 AM
well loopbacks are include into many lists
there is two connections per device
so there are two connections from 6513 to other 6513, two connections from 3750e to 6513 (flapping), two connections from 3750e to 6513. all Connections are Fiber
I have do the show cdp neighbors details and summary command to verify those connections are connected
I have not done debugs on eigrp because last network guy did it still trying to find them and plus trying to get the
maintenance window to do this, looking like the window will have to be next week
I would like to see the debugs myself as well
I am going to change the loopback to passive in the maintenance
09-19-2013 02:15 PM
Any chance you have a duplicated IP address so your unicast is broken? I think the loopback interface stuff is a rabbit trail. It appears you have multicast in both directions (because of entries in neighbor tables) but unicast only working in one direction. Since the Q count is 0 on the 3750, he is receiving acks successfully, bit the retry limit exceeded with a Q count value means the 6500 isn't getting acks.
Have you tried pinging with full packet sizes in case of mtu problem?
09-19-2013 02:54 PM
Donald,
I labbed this up and was able to get the same result:
interface Loopback1
ip address 1.1.1.2 255.255.255.255
end
R2(config-router)#network 1.1.1.0 0.0.0.255
R2(config-router)#
*Mar 1 00:24:04.643: EIGRP: Packet from ourselves ignored
*Mar 1 00:24:09.315: EIGRP: Packet from ourselves ignored
*Mar 1 00:24:14.215: EIGRP: Packet from ourselves ignored
Debug those packets:
*Mar 1 00:30:04.671: EIGRP: Sending HELLO on Loopback1
*Mar 1 00:30:04.675: AS 100, Flags 0x0, Seq 0/0 idbQ 0/0 iidbQ un/rely 0/0
*Mar 1 00:30:04.683: EIGRP: Received HELLO on Loopback1 nbr 1.1.1.2
Notice that I have a /24 mask for a /32 host. If I specify the /32, the error goes away. So, the loopback could be an issue without an address conflict.
HTH,
John
*** Please rate all useful posts ***
09-20-2013 04:43 AM
My point was not that the packet from ourselves message is not related to the retry limit exceeded, which is the real problem
09-20-2013 07:06 AM
well Donald how would you test to see if the unicast is broken ?
I have ping to the 3750e to 6513 and back with mtu size 1500 repeat 1000 also used source vlan 48 all are successfully no drop packets.
Well how would you fixed retry limit exceeded problem ?
09-20-2013 06:34 AM
Configure no auto-summary on 3750 switch and also check the any multicast packet blocks on the link......
09-20-2013 07:17 AM
Is the mtu the same on both ends? Is the problem continually happening? Is there anything between the two routers/switches or are there other devices between them that could be creating an issue? Check the arp entries to make sure that the mac address is what is expected (looking for a duplicate).
Another thing to try is to do the extended ping with a range of sizes and payloads rather than a fixed size.
09-20-2013 07:54 AM
Donald
I have ping both sides with different mtu size and repeat it like 100, 1000, 10000
MTU size i have try is 64, 1000, 1100, 1500.
There is nothing between these devices
We would it matter if arp entery to a mac address is being used by more than one device?
09-20-2013 07:57 AM
Maybe I don't understand your question, but if the MAC address mapping in the ARP table is incorrect, then unicast will be delivered to the wrong device. Pings would work (the wrong guy would be answering) but EIGRP wouldn't function.
09-20-2013 08:17 AM
Well Donald, I am litte confused myself by (
Question
can you show me a example of this please
Thank you
