02-05-2009 02:18 PM - edited 03-04-2019 01:07 AM
Does anyone know what image I need to get to support EIGRP on some 851W routers I purchased for remote users?
Here is what I have on them now.
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T7, RE
LEASE SOFTWARE (fc3)
Here is what IOS tells me when I try to configure EIGRP.
richbob(config)#router eigrp 1
Protocol not in this image
I'm confused, I thought that when I feature was not available, it did not show in the help ? command..
02-05-2009 03:05 PM
Hi Brantley,
The 851W does not support EIGRP. Other option would be a 871W.
Lejoe
02-05-2009 03:07 PM
From the below link it seems only 870 series supports EIGRP when using advanced ip services or advanced enterprise services
have a look at the general software section below
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html')">http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
Narayan
