eigrp originating router question
DARYLE DIANIS
hi, I have a question I cannot figure out.  I ran this sho ip eigrp top command and the originating IP address is no where on my network that I can find.  I looked at CDP neighbors, pings don't answer, traceroute doesn't turn up anything.  Any thoughts where that IP came from?
thanks,
sho ip eigrp top 167.174.148.0 255.255.255.0
EIGRP-IPv4 Topology Entry for AS(1)/ID(192.168.31.1) for 167.174.148.0/24
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2816
  Descriptor Blocks:
  0.0.0.0 (Vlan19), from Connected, Send flag is 0x0
      Composite metric is (2816/0), route is Internal
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 10 microseconds
        Reliability is 255/255
        Load is 16/255
        Minimum MTU is 1500
        Hop count is 0
        Originating router is 192.168.31.1
Richard Burts
The field for originating router is based on the router ID of the router that originated the advertisement. I was about to suggest that someone had configured the router ID for their EIGRP process and perhaps had fat fingered the address and that might be difficult to find the router. Then I noticed these lines of output
    Hop count is 0
If the hop count is zero then it appears that the advertisement originated on your router. So would you please post the output of the command
show run | beg router eigrp
Rick
Rick
