EIGRP over ATM
subra4u
We are trying to run EIGRP over ATM and for some reason the eigrp neighborship wont come up. Please find the interface details and the sho ver from the router. Cisco Feature Navigator says it will support.
Thanks in advance,
13 Replies 13
lamav
Level 8
Level 8
Hi:
Why are yo using a multipoint configuration? Can you show us the other end of the EIGP neighborship? Have you thought of implementing a point-to-point configuration?
Victor
Thanks for your quick response. The Multipoint configuration has been there for a while now. Please find the configuration of the other end below
interface ATM0/0
no ip address
atm pvc 1 0 5 qsaal
atm pvc 2 0 16 ilmi
atm idle-timeout 20
atm ilmi-keepalive
interface ATM0/0.1 multipoint
ip address 172.20.254.1 255.255.255.0
atm esi-address 000000000000.01
svc slab nsap 47.000580FFE1000000F21C3D1E.000000000000.01
protocol ip 172.20.254.254 broadcast
ubr 10000 10000
oam-svc manage 1
oam retry 1 5 1
Router#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 14-Jan-02 22:40 by pwade
Image text-base: 0x600089A8, data-base: 0x611B2000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
Router uptime is 6 days, 17 minutes
System image file is "flash:c3640-is-mz.122-7.bin"
cisco 3640 (R4700) processor (revision 0x00) with 57344K/8192K bytes of memory.
Processor board ID 15140639
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
4 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Hello Sundaram,
you are using ATM SVCs.
First of all, is ATM SVC up ?
from router1 can you ping 172.20.254.254 ?
post sh atm svc
Hope to help
Giuseppe
garsmi
can you also attach the eigrp config for both sides. Are you using the same AS on both sides for EIGRP?
Thanks for your quick response. Please find the requested info.
Router-2#sh atm svc
0/0.1 siteb 0 109 SVC SNAP UBR 10000 UP
Router-1#sh atm svc
2/0.1 sitea 0 475 SVC SNAP UBR 10000 UP
Router-2
router eigrp 100
network 10.254.0.0 0.0.255.255
no auto-summary
no eigrp log-neighbor-changes
Router-1
Do not show anything on the running config. But when tried again, it says EIGRP runs on the same AS. What could be wrong here.
Thanks in advance,
subra
can you do a sh ip protocols on both routers?
are you saying on router 1 when you did the sh run, nothing came up at all????? & that you had to try a 2nd time to get anything to come up?
Thanks for the response. Please find the requested info.
Router-2#sh ip protocols
Routing Protocol is "eigrp 100"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: eigrp 100
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
10.0.0.0/16
Passive Interface(s):
FastEthernet1/0
Routing Information Sources:
Gateway Distance Last Update
Distance: internal 90 external 170
Router-1#sh ip protocols
Router-1#
Router-1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router-1(config)#router eigrp 100
Router-1(config-router)#neigh
Router-1(config-router)#neighbor 172.16.254.254 atm 2/0.1
EIGRP: Static nbr 172.16.254.254 already in AS 100 ATM2/0.1
Hello Sundaram,
on router-2 you see:
10.0.0.0/16
you need a network command for net 172.16.254.0/24 even if you use the neighbor command.
router eigrp 100
net 172.16.254.0 0.0.0.255
about router-1 check with
sh run | beg router eigrp
if missing add the same network statement here.
Hope to help
Giuseppe
After sometime now, we started working with this issue now and on two more routers we find the same issue.
We could enable the eigrp and type all the commands but it fails to show up on the show run. We double checked the feature set and it seems to be alright. what could be wrong here.
Please find the IOS Version details.
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router1 uptime is 30 weeks, 4 days, 3 hours, 23 minutes
System returned to ROM by bus error at PC 0x1, address 0x0
cisco 3640 (R4700) processor (revision 0x00) with 123904K/7168K bytes of memory.
Processor board ID 15900099
Bridging software.
3 FastEthernet/IEEE 802.3 interface(s)
24576K bytes of processor board System flash (Read/Write)
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(12a), RELEASE SOFTWARE (fc1)
Compiled Tue 24-Sep-02 00:30 by pwade
Image text-base: 0x60008930, data-base: 0x610F4000
Router2 uptime is 13 weeks, 6 days, 7 hours, 1 minute
System image file is "flash:c3640-is-mz.122-12a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 121856K/9216K bytes of memory.
Processor board ID 19739756
Bridging software.
32768K bytes of processor board System flash (Read/Write)
Any help is greatly appreciated.
subra
Hello Subra,
You need a network command for the IP subnet that is associated to the ATM link even if you use the neighbor command to avoid to use multicast Hello packets: it is the network command that decides if EIGRP is active on an interface or not.
Hope to help
Giuseppe
Subra,
We need to address the fact that you are unable to view the running-configuration before making any changes in any of the routers.
Both routers are running a very old code and I highly suggest doing some research for picking a newer release. There are a lot updates made to IOS in the last 6 years in terms of bugs and features.
With that said, let's try rebooting Router1 during a maintenance window and see if you are able to view the running-configuration once again. It seems the router has ran out of memory or it has hit a bug which has caused to crash some internal services which may be affecting EIGRP.
Please let us know if the reboot has fixed your issue before making any more changes in neighboring routers.
HTH,
__
Edison.
Thanks for the quick response.
We will have a maintenance window this month. Will do that and get back to you.
Subra
