09-12-2011 02:35 PM - last edited on 03-25-2019 03:33 PM by ciscomoderator
Hi Everyone,
I have a question regarding EIGRP.
I have an ASA and two 3750 switches connected as follows ASA---eth----Cat3750_1----eth----Cat3750_2
All of them are configured for eigrp 100. Routes are being exchanged between ASA and Cat3750_1 and between
Cat3750_1 and Cat3750_2. But for some reason I cannot see the routes being exchanged between Cat3750_2 and ASA.
Below is my configuration, I am wondering what I forgot to put. Thanks!
I have configured eigrp 100 as follows:
ASA
router eigrp 100
no auto-summary
network 192.168.1.0 255.255.255.0
redistribute static
show ip route
D 10.100.100.0 255.255.255.252 [90/28416] via 192.168.1.2, 0:11:40, inside
C 10.10.10.0 255.255.255.0 is directly connected, outside
S 192.168.0.0 255.255.255.0 [1/0] via 10.10.10.10, outside
C 192.168.1.0 255.255.255.0 is directly connected, inside
S* 0.0.0.0 0.0.0.0 [1/0] via 10.10.10.10, outside
Cat3750_1
router eigrp 100
network 10.100.100.0 0.0.0.3
network 192.168.1.0
eigrp stub connected summary
show ip route
10.0.0.0/30 is subnetted, 1 subnets
C 10.100.100.0 is directly connected, Vlan100
D EX 192.168.0.0/24 [170/28416] via 192.168.1.1, 00:12:47, Vlan200
C 192.168.1.0/24 is directly connected, Vlan200
D 192.168.2.0/24 [90/3072] via 10.100.100.1, 00:10:11, Vlan100
D*EX 0.0.0.0/0 [170/28416] via 192.168.1.1, 00:12:47, Vlan200
Cat3750_2
router eigrp 100
no auto-summary
network 192.168.2.0
show ip route
D 192.168.1.0/24 [90/3072] via 10.100.100.2, 00:11:21, Vlan100
C 192.168.2.0/24 is directly connected, Vlan300
09-12-2011 03:36 PM
Your 3750_1 is configured as stub - any reason for that? That's the reason why the routes are not passing downstream to other routers.
09-12-2011 04:26 PM
Hi, any idea if non stub eigrp supported on 3750 ip base?
09-12-2011 04:38 PM
You didn't mention the feature set - you need IP Services for full EIGRP support.
