EIGRP routes in active
espmolina
1. Will it be helpfull to increase the "timers active-time" before EIGRP routes are placed on SIA.
2. If yes, what is an ideal value?
3. The default is 3 mins before routes placed on active are placed on SIA, is this right?
4. Here is my problem, I have some low-speed FR connections that flaps and some dial-in users and is causing havoc to my network. I understand that the presence of an active route in the EIGRP means the network has not converge. Any idea would be very much appreciated.
John
Hello John,
which routes are SIA ? Normally, the SIAs should only occur for the routes from the dialup clients, which would actually be expected behaviour.
For the low-speed FR connections, make sure that you have the correct ´bandwidth´ statement configured on the interface, reflecting the actual bandwidth provided, otherwise EIGRP might have problems pacing the EIGRP packets.
GP
The dial-up users are on SIA. My analysis is that the I never get response to queries sent over the FR that is the reason why the dial-up networks goes SIA.
I have some ideas on how to curtail the queries. Your ideas will very much appreciated.
Thanks.
