EIGRP routing data TCP to the right, UDP to the left
Hi all,
Hope to find everyone well
I was asked to do the following by a consultant of my costumer but I don't know if that is even possible. Basically I have eigrp applied and it has its routes elected and he wants me to send TCP traffic let's say to the left and UDP traffic to the right...
Is this even possible??
I can do uneven load balancing with eigrp and that's the only way I'm seeing of sending traffic both ways of the ring, but discerning, this traffic goes left and this traffic goes right being routed with eigrp...
Any help is much appreciated
Thank you
17 Replies 17
Hello
Looks like PBR is supported on either network essentials or advantage packages -here
Kind Regards
Paul
I confirm, yesterday was preparing 6 Catalyst 9300 and saw that supports both the PBR and the availability function.
Now it's to apply on the system.
Thank you all for the amazing help
Hi all,
I was executing all this config now and I hope everything is ok. The below appears correct?:
ip sla 1
icmp-echo 10.1.254.2
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.6.254.2
track 10 sla 1 reachability
track 20 sla 2 reachability
interface vlan 40
description LAN
ip policy route-map TCP_UDP_RM
route-map TCP_UDP_RM permit 10
match ip address 101
set ip next-hop verify-availability 10.6.254.2 track 10
route-map TCP_UDP_RM permit 20
match ip address 102
set ip next-hop verify-availability 10.1.254.2 track 20
access-list 101 permit tcp any any
access-list 102 permit udp any any
Basically if one fails the other link takes over am I correct?
Thank you
