eigrp summary administrative distance
Lassek
When creating an EIGRP summary it will automatically install on the local routing table a route to Null0, this route has an AD of 5.
Is there a command that will display this AD of 5 anywhere?
It's just out of curisity
Cheers
Lasse
You should be able to see it in the routing table.
You might have to specify the summary address appended to the command.
Ex: show up route <summary address/mask>
R#sh ip route 172.16.0.0 255.255.254.0 Routing entry for 172.16.0.0/23 Known via "eigrp 1", <strong>distance 5</strong>, metric 28160, type internal Redistributing via eigrp 1 Routing Descriptor Blocks: * directly connected, via Null0 Route metric is 28160, traffic share count is 1 Total delay is 100 microseconds, minimum bandwidth is 100000 Kbit Reliability 255/255, minimum MTU 1500 bytes Loading 1/255, Hops 0
Hope that helps.
AD default is 5
Show ip route summary address <-in the router generate the summary
summary-metric summary address distance X <- this change the default to any AD you want.
Thanks that's what I needed
I forgot about that command
