Cisco ASR 1000 IPB to AES Upgrade
Hi all,
did anyone done IPBase to Adv Enterprise upgrade for cisco ASR 1002-HX?
i found relevant part code is L-SLASR1-IPB-AES=. but didnt found any installation guide or clear ordering guide.
can someone help with required ordering parts and upgrade process?
Thanks in advance
Good luck
KB
balaji.bandi
Hi @balaji.bandi thanks for quick reply. i have gone through second document already. according to that below command can use to enable evaluation license.
Router(config)#license boot level adventerprise
but i didnt found any indication about permanent license installation and activation commands.
and do you have any idea about ordering parts for this?
will L-SLASR1-IPB-AES= enough or any other things to purchase?
Good luck
KB
Depends on what version code running here if this is smart License then smart License.
if this is PAK then we go traditional installation : (hope is this what you looking i guess right)
https://www.cisco.com/c/en/us/products/ios-nx-os-software/ios-software-activation/index.html
BB
