EIGRP tweak
Ricky S
Level 3
Level 3
Hi everyone, please refer to the attached exhibit.
- Router C and Router D are DMVPN head-end routers located at the Data center
- C and D have a direct connection with each other via a layer 3 switch
Q: How can I have Router C advertise a better route for all branches to the Layer 3 switch so that the switch would prefer Router C for all branches?
2 Accepted Solutions
cflory
Assuming you're using EIGRP (not specified), you could influence routes via bandwidth or delay setting (K1 and K3 values), or even an offset:
(previous discussion):
https://supportforums.cisco.com/thread/2083284
or:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml
HTH!
-Chris
cflory
or:
HTH!
-Chris
You must set the metric according to the link below:  http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml  Regards, Leo
Thanks Gents, I just spent the last hour studying the link you sent and have learnt quite a bit from it. I think I am going to use the offset list to influence the metric on the layer 3 switches.
