Line Card Problem
sarifulcisco
please see the below log file of cisco switch and suggest me what i can i do for that situation:
Switch Log :
%PM_SCP-SP-1-LCP_FW_ERR: System resetting module 2 to recover from error: Linecard received system exception
%OIR-SP-3-PWRCYCLE: Card in module 2, is being power-cycled Off (Module Reset due to exception or user request)
%C6KPWR-SP-4-DISABLED: power to module in slot 2 set Off (Module Reset due to exception or user request)
Switch card Inforamtion :
   Card Type                              Model              Serial No.
CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL104894TU
  MAC addresses                       Hw    Fw           Sw           Status
  0018.b9d1.2878 to 0018.b9d1.28a7   2.5   12.2(14r)S5  12.2(18)SXE6 PwrDown
Jun  3 03:51:07.154 UTC: %PM_SCP-SP-1-LCP_FW_ERR: System resetting module 2 to r
Jun  3 03:51:07.154 UTC: %OIR-SP-3-PWRCYCLE: Card in module 2, is being power-cy
Jun  3 03:51:07.154 UTC: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set Of
  Sub-Module                  Model              Serial        Hw     Status
  Distributed Forwarding Card WS-F6700-DFC3BXL   SAL10425HLU   5.3    PwrDown
please help me..
Sariful
cflory
%PM_SCP-1-LCP_FW_ERR: System resetting module [dec] to recover from error: [chars]
Problem
The switch reports this error message:
  • %PM_SCP-1-LCP_FW_ERR: System resetting module [dec] to recover from error: [chars]
These examples show the console output that is displayed when this problem occurs:
  • %PM_SCP-SP-1-LCP_FW_ERR: System resetting module 13 to recover from error: Linecard received system exception
    or
  • %PM_SCP-SP-1-LCP_FW_ERR: System resetting module 4 to recover from error: Coil Pb Rx Parity Error - Port #14
Description
The message indicates that the firmware of the specified module has  detected an error. The system automatically resets the module in order  to recover from the error. The [dec] is the module number, and [chars]  is the error.
Workaround
Reseat the module or put the module in a different slot and allow the  module to go through the complete bootup diagnostics test. For more  information on online diagnostics on the Catalyst 6500 series switches,  refer to Configuring Online Diagnostics.  After the module passes the diagnostics test, monitor the recurrence of  the error message. If the error occurs again or the diagnostics test  detects any issues, create a service request with Cisco Technical Support for further troubleshooting.
HTH!
-Chris
