Bookmark
Subscribe
1778
EIGRP
How many network commands would be needed to connect 4 routers?
12 Replies 12
Jon Marshall
How many do you think it is and why ?
Jon
I thought it was 2, because you can add more than one IP to a command.
I make it two as well because if you cannot use an inverse mask then EIGRP will assume the classful mask so the two statements would be -
network 192.168.64.0
network 192.168.72.0
which covers all the interfaces.
Note though that 192.168.64.0 covers a lot more but that is not what the question is asking so I am assuming that is the right answer.
Jon
Hello
You could do it with one network command
HK rtr
router eigrp xxx
network 0.0.0.0
Kind Regards
Paul
Paul
I thought it had to be -
network 0.0.0.0 0.0.0.0
or
network 0.0.0.0 255.255.255.255
but either way you need to use an inverse mask.
Jon
Hello Jon
my understanding mate its just the one syntax to enable eigrp on all connected interfaces no inverse is required
Kind Regards
Paul
Paul
I need to test that because I thought "network 0.0.0.0" was used to advertise the default route in EIGRP not match all the interfaces ie. a special use case but I could well be wrong.
Jon
since this appears to be CCNA level stuff. I would agree with @Jon Marshall that you need to classful networks.
The 'network 0.0.0.0' statement as suggested by @paul driver would work perfectly, but I think they want you to define the networks...
Hello
What is the minimum number of EIGRP network commands on HongKong, without inverse masks, so that all 4 of the directly connected links on HongKong are enabled for EIGRP?
I read it as no inverse mask and all directly connected networks as such 0.0.0.0 would be applicable
Kind Regards
Paul
@paul driver You are technically absolutely correct, but I honestly think that in the context of a CCNA level exam, 'network 0.0.0.0' is not the answer. Even in the higher level exams, 0.0.0.0 never shows up. Actually, I have never seen it configured at all in a 'real' network (which doesn't mean much because I have probably seen only a small fraction of all networks)...
So it's not two, it's one?
Hello
Yes - i would say one
Kind Regards
Paul
