HA between routers 2911
mateomateo1
I have to build HA environment, at the moment we have only one R1 and WAN1 but company wants to buy R2 + WAN2 and have HA between the routers, in case R1 or WAN1 goes down the other router will take over.
What would be standard methodology nowadays to do that  - does HSRP will do what I need or it is better do some other way? can anyone point me in the right direction.
Matt,
Here is some of the information for this:
Network Diagram
This document uses the network setup shown here:
In this diagram, Router 1 (R1) and Router 2 (R2) are in AS 100, which       has external BGP (eBGP) peering with ISP-A (AS 300) and ISP-B (AS 400)       respectively. Router 6 (R6) is a part of AS 600, which has eBGP peering with       ISP-A and ISP-B. R1. R2 has iBGP peering, which is necessary to ensure optimal       routing. For example, when you try to reach AS 400 internal routes, R1 does not       employ the longer path over AS 300. R1 forwards the traffic to R2       instead.
R1 and R2 are also configured for HSRP over a common Ethernet segment.       Hosts on the same Ethernet segment have a default route that points towards the       HSRP standby IP address 192.168.21.10.
Configurations
R1
Current configuration
hostname R1
interface serial 0
ip address 192.168.31.1 255.255.255.0
interface Ethernet1
  ip address 192.168.21.1 255.255.255.0
  standby 1 priority 105
  standby 1 preempt delay minimum 60
  standby 1 ip 192.168.21.10
  standby 1 track Serial0
!--- The
standby track serial command tracks the state of
!--- the Serial0 interface and brings down the
!--- priority of standby group 1, if the interface goes down.
!--- The
standby preempt delay minimum 60 command makes sure that
!--- R1 preempts and takes over as active router again. This command also ensures that
!--- the router waits 60 seconds before doing so in order to give BGP time enough
!--- to converge and populate the routing table. This avoids
!--- traffic being sent to R1 before it is ready to forward it.
router bgp 100
  no synchronization
  network 192.168.21.0
  neighbor 192.168.21.2 remote-as 100
  neighbor 192.168.21.2 next-hop-self
  neighbor 192.168.31.3 remote-as 300
  no auto-summary
R2
Current configuration:
hostname  R2
interface serial 0
ip address 192.168.42.2 255.255.255.0
interface Ethernet1
 ip address 192.168.21.2 255.255.255.0
 standby 1 priority 100
 standby 1 preempt
router bgp 100
 no synchronization
 neighbor 192.168.21.1 remote-as 100
 neighbor 192.168.21.1 next-hop-self
 neighbor 192.168.42.4 remote-as 400
 neighbor 192.168.42.4 route-map foo out
!--- It appends AS 100 to the BGP updates sent to AS 400
!--- in order to make it a backup for the ISP-A to R1 path.
 no auto-summary
access-list 1 permit 192.168.21.0
route-map foo permit 10
 match ip address 1
 set as-path prepend 100
end
Verify
This section provides information you can use to confirm your       configuration is working properly.
Certain show commands are supported by the       Output Interpreter Tool (registered customers only)         , which allows you to view an       analysis of show command output.
When you configure redundancy in any network, you must consider two       things:
  • The creation of a redundant path for packets going from a local           network to a destination network.
  • The creation of a redundant path for packets coming back from a           destination to a local network.
This information was from the link I gave you.
Thanks and Cheers!
Kimberly
Please remember to rate helpful posts.
Thanks and Cheers! Kimberly Please remember to rate helpful posts.
7 Replies 7
Kimberly Adams
Level 3
Level 3
Matt,
Yes HSRP would be the best way to have HA and failover to the R2 and WAN2.  You would need to configure your HSRP to track your WAN1 and failover to R2 and WAN2 if WAN1 link goes down.  If you need some configuration assistance let me know.
Thanks and Cheers!
Kimberly
mateomateo1
Thank you for quick reply, if you dont mind Kimberly I would appreciate for link or example on how to do this.
Matt,
Here is a link for the basics of configuring HSRP:
http://www.cisco.com/en/US/customer/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml
This link shows how to do this with BGP, but the basics of HSRP are there with some configuration examples and diagrams.  Be sure to track the serial interface, so when it goes down it will failover to the R2 with WAN2.
Thanks and Cheers!
Kimberly
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, HSRP might be used.  GLBP too, if you want to try better gateway load balancing.
However, since your diagram shows a dual 3750 stack, and since 3750s can route, I would suggest putting the LAN gateway(s) on the stack and routing between the L3 enabled 3750 stack and your WAN routers.  You also might want to MEC between the 2911s and your stack (good if you can do same for your edge 2960s too).
mateomateo1
I cant access that website , it says i do not have permissions ... could you post some other link please
Sent from Cisco Technical Support Android App
Matt,
Network Diagram
Configurations
R1
hostname R1
interface serial 0
interface Ethernet1
!--- The
!--- The
router bgp 100
  no synchronization
  no auto-summary
R2
hostname  R2
interface serial 0
interface Ethernet1
 standby 1 preempt
router bgp 100
 no synchronization
 no auto-summary
 match ip address 1
end
Verify
Thanks and Cheers!
Kimberly
thank you, it worked great!
just have a question if i add extra 3750-x to my scenario will that need extra config for routers or switches? sothing like that:
could you also point me or recommend a book with different types of set-ups (for high availibility) on cisco devices please.
