Enable new board E1 - Cisco 3640???
aclaverie
I've plugged an E1 board (NM-1CE1T1-PRI) in slot 3 of my cisco 3640 (release 12)
The board is shown as "unknown (type 925)
I don't find any command to configure it..
Can anybody help me please
Anne
6 Replies 6
lgijssel
Level 9
Level 9
Hello Anne,
I am afraid I have bad news for you. According to the following URL:
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_documentation_roadmap09186a00802c6e98.html#wp1060743
the module is not supported in the 3640. Please verify this for yourself if you want. The reference is under the header: Product Information and Supported Hardware and Software
Leo
As ritely said by leo its not supported in 3640 but in otherways i have seen them working in 7200VXR boxes without any issues..
Also refer this link for possible module support in 3640.
http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_data_sheet09186a0080091f6f.html
regds
Hello Anne,
I think you need to configure the following:
Router> enable
Router# configure terminal
Router(config)# card type t1
Router(config)# controller t1
That is obviously only valid when you card is recognized by the IOS. Can you post the output of ´show version´?
GP
Thanks for all you reply.
here after is the result of "show version"
The command "card type ..." is not accepted (give me "unrecognized command" )
but I'm trying to configure from ethernet connection.
May be it's a console command.
I'll go on site today . I'm almost sure this board should work with this cisco... ;-)
router1#sh version
IOS (tm) 3600 Software (C3640-I-M), Version 12.0(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 14-Oct-99 11:48 by phanguye
Image text-base: 0x60008918, data-base: 0x6067A000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
router1 uptime is 2 days, 18 hours, 31 minutes
System restarted by power-on
System image file is "flash:c3640-i-mz.120-7"
cisco 3640 (R4700) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID 26391485
R4700 processor, Implementation 33, Revision 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
4 Ethernet/IEEE 802.3 interface(s)
35 Serial network interface(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0x2101
Hello Anne,
my post was misleading, Leo and Edwin are right: there is no hardware support for the card on your 3640:
NM-1CE1T1-PRI & NM-2CE1T1-PRI
--> not supported on Cisco 3620, 3640, 3640A, 2610-51 (non-XM models)
--> compatible with:
Cisco 2610-51XM (IOS 12.3 & 12.3T)
Cisco 2691 (IOS 12.3 & 12.3T)
Cisco 3660 (IOS 12.3 & 12.3T)
Cisco 3700 series (IOS 12.3 & 12.3T)
GP
hello,
yes I saw the document... bad luck for my customer ;-)
they will try to find another board or another router.
Thanks for all
Anne
