isdn bri leased line between two cisco routers
elnurh
Hi everybody.
Hi have some problems with connect two cisco routers between yourself with isdn bri leased line
config is very simple.
How can I do it ?
there are a some config from routers
fisrt router config
isdn switch-type basic-net3
isdn leased-line BRI0/0 128
interface BRI0/0
ip address 172.55.20.1 255.255.255.0
encapsulation ppp
second router config
interface BRI0/0
ip address 172.55.20.2 255.255.255.0
encapsulation ppp
what's wrong maybe I not write something please help me to solve this problem.
thanks before
is this for a lab environment, that is, is this a back-to-back config ? If so, it might be that you need to provide the ´clock rate´ at one end of the connection, e.g.:
Router1
interface BRI0/0
encapsulation ppp
clock rate 125000
In the configuration examples that I have seen, the ´bandwidth 128´ command is added under the interfaces, not sure if that makes a difference:
Router1
interface BRI0/0
encapsulation ppp
bandwidth 128
Router2
interface BRI0/0
encapsulation ppp
bandwidth 128
GP
not working
BRI0/0 is down, line protocol is down
Hardware is PQUICC BRI with U interface (Infenion)
Internet address is 172.55.20.2/24
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Closed, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 12:37:07
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 96 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
From the supporting doc i just found to make use of HDLC as the encapsulation can u just try changing it out on both the ends and check ??
also refer the statement mentioned below..
"Because of the leased-line—not dialed—environment, configuration of ISDN called and calling numbers is not needed and not used. The BRI 0 interface is henceforth treated as a synchronous serial interface, with the default High-Level Data Link Control (HDLC) encapsulation"
regds
it looks like you have a physical problem - how are the routers connected to each other ? Do you have e.g. an ISDN simulator ?
GP
