about isdn .. pls help
pccthailand
Hi all
1. I'm not sure about the backup interface command , this command can use one interface on single router ? if i would like to use backup two interface it can't ??
2. pls explain me about isdn bandwidth , i'm not sure it's 144 kbps or 192 kbps
thanks for kindly
imnilesh
Hi;
you can use like this :
interface Serial0/0/1
description XXXXX
bandwidth 64
ip address XXXXXX XXXXXXXXX
ip accounting output-packets
backup delay 2 2
backup interface BRI0/1/0
hope this will help...
//nil
thisisshanky
Level 11
Level 11
backup interface command can be used on multiple interfaces
isdn bri bandwidth is 128 kbps (each B channel = 64kbps) and 16 kbps of signalling channel (D channel). That adds to 144 kbps. This is the actual data rate.
With framing bits added there is another 48 kbps required for transmitting framing bits. This total adds up to 192 kbps.This rate should be called as the actual bit rate.
I do not think, that you can use the isdn interface as backup to multiple serial interfaces. As I once do remember, that it showed an error message saying,
"ISDN BRI interface is already a backup interface to serial 0"
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
pccthailand
hello
if i config ppp authentication chap on dialer profile , i have to use dialer remote-name every time ?
thanks for your kindly
