Enabling CEF
Chris Deren
Is it safe to enable CEF on a router during business hours?
Chris
cpembleton
Level 4
Level 4
You should not have a problem. I would reference your companies change management procedures. If you are having a problem like high CPU utilization then you would probably not want to wait. If your not having any issues your better of waiting until after hours.
devang_etcom
Level 7
Level 7
hi Chris,
its depends upon your CPU utilisation.
CDF will help to reduce the load.
regards
Devang
sean
Level 3
Level 3
Just check the memory utilization as well as cef does consume more memory than other switching methods. Also, if you are doing this on a distributed platform, be sure to use the ip cef distributed command to get the most benefit.
