Enabling SFP Module on Cisco ISR 2921
Ramesh Chauhan
                   Can anyone tell me how to enable the SFP module on cisco 2921?
mahmoodmkl
Level 7
Level 7
i think u r refering to sfp port on the router if this the thn u need to go under the interface n type media-type sfp
Leo Laohoo
the router needs to run the correct IOS version and all you need is plug it in.
Please provide other relevant info:
1.  sh version;
2.  what module are you trying to use.
3.  sh inventory
Here are the Outputs of sh inventory and sh version
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V06 , SN:  XXXXXXXXX
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 , SN: FOC161831MB
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: XXXXXXXXX
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC16124ZB8
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID     , VID: V03 , SN: FOC16177NXM
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC161344QN
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V03 , SN: QCS1606H0A0
sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
CFC-Bryan239 uptime is 5 days, 5 hours, 35 minutes
System returned to ROM by reload at 23:52:56 UTC Fri Feb 15 2013
System restarted at 23:55:00 UTC Fri Feb 15 2013
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID XXXXXXXXX
3 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          XXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
I have connected a 10 Gig SFP module on the ISR. It worked for a day but when we reloaded   the router it was not detecting the SFP module and currently we have to use the copper cable to connect to gig0/1 instead of a fiber cable.
mahmoodmkl
Level 7
Level 7
