error message in log
rplacier
I am getting the following error message on our 10700 router:
%SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x50314770, alignment 32
Pool: I/O  Free: 60224  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Net Background", ipl= 0, pid= 27
-Traceback= 5035CEB8 5035E8C0 50314778 50314B00 5031510C 50013A0C 500427C0 5032B2B0 5032B578
I've read that this could be a bug or I just need to update the IOS on this router.  Any advice?  System image file is "flash:c10700-p-mz.120-30.S.bin"
Thanks in advance.
Mohamad Qayoom
Level 3
Level 3
Reloading the router could also solve the issue, but if the you notice the message again, you may need to upgrade IOS or replace the router.
Mohamad Qayoom
Level 3
Level 3
Thanks for the assistance.  I'll upgrade the IOS and reload the router.  Hopefully this will take care of the issue.
