Error message while deleting the pcm.dat file from cisco 2811 router
waqas0612147
Hi all,
When I tried to delete the file from cisco 2811 router. It shows the following error messages.
%Error deleting flash:/pcm.dat (File in use in an incompatible mode)
Tell me how I delete the file from router.
Ali Raza
vragotha
Level 3
Level 3
Try disabling the captures and then delete the pcm.dat file
It should be something like -
no voice hpi capture
no voice hpi capture destination flash:pcm.dat
7 Replies 7
paolo bevilacqua
Extact flash (nothing bad will happne), inser in PC, delete file, put back in router.
Is there any solution for this? Because the router is working in live enviornment and it is very difficult to take a down time for this.
LHR-LDA-JT-DC-RTR#delete flas
LHR-LDA-JT-DC-RTR#delete flash:pcm.dat
Delete filename [pcm.dat]?
Delete flash:/pcm.dat? [confirm]
LHR-LDA-JT-DC-RTR#
Ali Raza
Solution given above, 0 down time.
How could we remove the flash when server in running condition. I also don't have a slot in PC to insert a flash. Please tell some other suggestion to resolve this issue.
Ali Raza
Again for the hird time, you can remove the flash with the router running without any problem.
Then you get a $10 usb card reader to delete the file.
vragotha
Level 3
Level 3
Hi Vijay,
Thanks....In first command I just add buffer in last..
no voice hpi capture buffer
Ali Raza
