ERROR ON A VOICE GATEWAY ROUTER
vaibhav-g
Hi Team
When we connect console to the router, we are getting the following error message continuously
%TCP-6-NOBUFF: TTY0, no buffer available -Process= "SCCP Application", ipl= 0, p
id= 241 -Traceback= 0x414AA310 0x41C52D18 0x41C5CB7C 0x41C5CEEC 0x41C5F9F4 0x41C
200E4 0x41C27170 0x40D5327C 0x40D54610 0x40D592E8 0x40D594B8 0x40D5966C 0x40D4FF
B8 0x40D50288
we are getting following error,plse sugesst what could be the issue and workarround for the same
Vaibhav
ebreniz
Level 6
Level 6
You can use Error Message Decoder tools from cisco.com
%TCP-6-NOBUFF: TTY[t-line], no buffer available. An internal software error has occurred.
Recommended Action: Copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
Related documents- No specific documents apply to this error message.
Mark Yeates
Level 7
Level 7
Which router are you using , and what IOS are running? Traceback errors are usually associated with internal software issues.
Mark
