Error Update IOS router 7600
ecostaalfaia
Hi Guys,
I've trying updating a 7609 cisco router, my actual image that is working is "c7600s72033-advipservices-mz.122-33.SRB5" and I would like to update to "c7600s72033-adventerprisek9-mz.122-33.SRC2". I've followed all the steps to update but when I've reloaded the router happen the error below:
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot disk0:c7600s72033-adventerprisek9-mz.122-33.SRC2.bin"
Loading image, please wait ...
open: file "c7200-atafslib-m" not found
monlib.open(): Open Error = -1
loadprog: error - on file open
cannot load the monitor library "disk0:%c7200-atafslib-m" from device: PCMCIA Disk 0loadprog: error - on file open
boot: cannot load "disk0:c7600s72033-adventerprisek9-mz.122-33.SRC2.bin"
Exit at the end of BOOT string
rommon 1 >
The error in red I think that is the problem, How could I solve this problem?
Thanks Guys
Leo Laohoo
I think this is a monitor file.  Post the output to the command "dir disk0".
This error message is saying that the router cannot see the PCMCIA card or the PCMCIA card currently installed cannot be detected by the line card.
You can't load the monitor library file because the boot variable string is incorrect.  Look at the highlighted (in RED) above.  The boot variable string found in the configuration has a space, the symbol "%", between the location (or "disk0:") and the filename.
