Etherchannel Interfaces in suspend mode
c.perez.l
Hello!!
I configured an Etherchannel two interfaces (Gi0/37 and Gi0/39) in a CiscoWS-C2960G-48TC-L, which is connected to an HP Blade, where they spend 2vlan (16 and 17).
The point is that they got these interfaces on a trial and upload these were in sleep mode produces the following log.
Sep 1 16:04:38.649:% EC-5-CANNOT_BUNDLE2: Gi0/37 is not Compatible with Po1 and Will be suspended (trunk mode of Gi0/37 is dynamic, is Po1 trunk)
Sep 1 16:04:38.733:% EC-5-CANNOT_BUNDLE2: Gi0/39 is not Compatible with Po1
and Will be suspended (trunk mode of Gi0/39 is dynamic, is Po1 trunk
Applied to equipment configuration is as follows:
interface Port-channel1
switchport trunk allowed vlan 16,17
switchport  mode trunk
switchport nonegotiate
speed 1000
duplex  full
spanning-tree portfast trunk
interface  GigabitEthernet0/37
description c7000te2-vc1
speed  1000
duplex full
channel-group 1 mode active
interface  GigabitEthernet0/39
speed  1000
duplex full
Any idea why interfaces are in "suspend"
regards
Atte.
César Pérez
tarang9974
Do you have work around or solution ?
19 Replies 19
cadet alain
Can you do sh int trunk and post output because apparently there is a trunking mode mismatch and I don't see that g0/39 is part of the PortChannel also.
Regards.
Alain.
Herewith the "show interface trunk"
switch # show interfaces trunk
Port Mode Encapsulation Status Native vlan
802.1q trunking 1 Gi0/47 on
802.1q trunking 1 Gi0/48 on
802.1q trunking 1 Po1 on
Port VLANs allowed on trunk
1-5,11-19 Gi0/47
1-5,11-19 Gi0/48
16-17 Po1
Port VLANs allowed and active in management domain
1,5,11-14,16-17 Gi0/47
1,5,11-14,16-17 Gi0/48
16-17 Po1
Port VLANs in spanning tree forwarding state and not pruned
Gi0/47 none
16-17 Po1
switch #
The interface belongs to Po1 Gi0/39 if I pasted the wrong configuration, my apologies. Again attached configuration Gi0/39.
speed 1000
duplex full
Regards!
César Pérez
Hi Cesar:
Tear down the existing configuration and start fresh. Also, remove the Port Channel that's already defined.
interface range gig0/37 , gig0/39
shutdown
switch trunk encap dot1q
switch mode trunk
no shutdown
PS: If configuring Active on the interfaces does not work, change it to passive. Before you do it, shut both interfaces prior to making the changes. Also ensure both devices have the same Native VLAN defined. If the port-channel comes up, then add the command "switch trunk allowed vlan add 16,17" under the port-channel 1. I hope this fixes your problem.
This is probably an LACP negotiation problem.
"LACP is supported on cross-stack EtherChannels from Cisco IOS Software Release 12.2(25)SEC and later. Switch interfaces exchange LACP packets only with partner interfaces with the active or passive mode configuration."
This is the HP switch. When the other side is in sleep-mode, a channel cannot be negotiated or maintained.
Link:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml#lacp
regards,
Leo
Thank you.
It would be nice this configuration?
   shutdown
   switch trunk allowed vlan 16,17
   switch mode trunk
   speed auto
  duplex  auto
   channel-protocol lacp
  no  shutdown
Thank you all for the answers.
César Pérez
Hi Cesar,
Avoid configuring the PortChannel first.
Try this ...
no int po 1
default int r g0/37 , g0/39
int r g0/37 , g0/39
switchport trunk allow vlan 16,17
switchport non
[optional]
channel-prot lacp
I would also make sure what the HP blade protocol is for NIC teaming or else the config wont work..protocol mismatch
tachavez
The datasheet for the 2960X mention that if any inconsistency is found in the interfaces participating in the etherchannel it will change the status of the interfaces of the 2960x to suspended.
I found in my case that the SFP´s and the "native" speed of the interfaces didn't match, meaning:
1.-some of the sfp´s status in the show inventory looked like: unspecified or no status at all
2.- the "native" speed of the interfaces were in the 3750x (1000BaseSX SFP) while in the 2960x (10/100/1000BaseTX).
I Hope this helps.
Taoki
tarang9974
Have you found out the issue ?
Assuming that you are using SFP´s and it goes in suspended mode. I found out that the 2960x switch needs to have connected the SFP´s on interfaces g1/0/25 and g1/0/27 instead of g1/0/25 and g1/0/26. As silly as it sound it prevents the etherchannel to form if not connected as described.
Yes, from the 4 SFP ports that I have on my 2960x Only the connectivity with the ports 25-27 and 26-28 worked
tarang9974
umer zubairi
Hi Dear,
I've exactly the same problem with my VSL port-channel
Let me know how did you get it resolved
BR,
I have the same problem on my 2960x but not with SFP mines with copper
