Expansion card not showing after installation on CISCO router 1921
JoseCobo73127
I bought a Cisco VWIC3-2MFT-T1/E1 2-Port T1/E1 Multiflex VWIC Card for my 1921 router, unfortunately is not showing the ports after the "show ip interface brief" command.
at this point I am quite lost, don't know if I ordered the wrong expansion card for the router or a configuration is needed on the device.
I am currently building my home lab to study and get ready to pass the CCNA 200-301 exam - The purpose of purchasing an expansion card was to connect two layer 3 switches.
Please Help and many many thanks!!!!!!
The following is some output from the router.
Router>show ip interface brief
Interface                                          IP-Address         OK? Method Status Protocol
Embedded-Service-Engine0/0        unassigned         YES unset administratively down down
GigabitEthernet0/0                          unassigned         YES unset administratively down down
GigabitEthernet0/1                          unassigned         YES unset administratively down downqq
Router>show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 12:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 12 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FJC2133L1U5
2 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
245744K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO1921/K9 FJC2133L1U5
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data None None None
NtwkEss None None None
Router#show diag
Slot 0:
C1921 Mother board 2GE, integrated VPN and 2W Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time 00:27:26 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC21287M0P
Hardware Revision : 1.0
Part Number : 73-12850-10
Top Assy. Part Number : 800-33408-04
Board Revision : H0
Deviation Number : 0
Fab Version : 02
Product (FRU) Number : CISCO1921/K9
Version Identifier : V05
CLEI Code : CMMHF10ARA
Processor type : C8
Chassis Serial Number : FJC2133L1U5
Chassis MAC Address : 002c.c8a8.97c0
MAC Address block size : 32
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 32 31 32 38 37 4D 30 50 40
0x10: 06 AC 41 01 00 82 49 32 32 0A C0 46 03 20 00 82
0x20: 80 04 42 48 30 88 00 00 00 00 02 02 CB 8C 43 49
0x30: 53 43 4F 31 39 32 31 2F 4B 39 89 56 30 35 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 46 31 30 41 52
0x50: 41 09 C8 C2 8B 46 4A 43 32 31 33 33 4C 31 55 35
0x60: C3 06 00 2C C8 A8 97 C0 43 00 20 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 51 40 00 8B 41 00 3C 42 00
0x80: 00 F8 00 24 03 E8 1B 11 07 D0 1E A2 09 C4 1F A9
0x90: 0B B8 20 0F 0F A0 20 D3 13 88 21 6A 1B 58 21 A9
0xA0: 1F 40 21 B8 27 10 21 3E 41 00 50 42 00 00 F8 00
0xB0: 18 02 71 1D B0 04 E2 20 08 07 53 21 02 0E A6 22
0xC0: 60 1D 4C 22 C4 27 10 22 C4 FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Top Assy. Part Number : 800-34658-01
Part Number : 73-13420-01
Board Revision : B0
Fab Version : 05
PCB Serial Number : FOC165199BY
Version Identifier : V01
Product (FRU) Number : VWIC3-2MFT-T1/E1
CLEI Code : COUIA7NCAA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
0x00: 04 FF 40 06 EF 41 01 00 C0 46 03 20 00 87 62 01
0x10: 82 49 34 6C 01 42 42 30 88 00 00 00 00 02 05 C1
0x20: 8B 46 4F 43 31 36 35 31 39 39 42 59 89 56 30 31
0x30: 20 CB 90 56 57 49 43 33 2D 32 4D 46 54 2D 54 31
0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 4E 43 41 41 03
0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
I don't think the VWIC3-2MFT-T1/E1 is supported at all on the 1921. It is supported on the 2951 and the 3925
Check Table 2 of the document linked below:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_4p_vwic3.html
Also check the section 'Platforms supported' in the document linked below.the 1921 is not listed...
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_vwic3.html#pgfId-1065554
balaji.bandi
I do see in your show version
use following guide to configure :
BB
Thank you very much for your help Georg, I didn't find the 1921 on table 2
regards,
Jose
