Extend Vlan to remote site
We need to extend a vlan to be exist with the same subnet on a remote site
I know it could be done using OTV with either Nexus or ASR
I need to know if there is another way to do this without these high cost boxes ?
We have a Layer 3 WAN connection to the remote site
6 Replies 6
You can also evaluate L2TPv3 to know if it is an option for you.Though it is simple, it has fewer capabilities.
OTV is a more robust approach for Data Centers.
I agree with Hector,
And it could be done over ISR routers.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes I agree with you Hector and Julio and many thanks for your comments
I think for ATOM if the customer is running over MPLS . and also think for L2TPV3 if there is simple ip connectivity.
But I think it won't help in case we need to do vmotion. Am I right ?
Also I think L2TPV3 need service provider interaction to configure the connect command on both PE routers on both sides.
The customer connectivity is 2 sites connected through IPSEC tunnel over internet. So Can we build L2TPV3 over IPSEC over internet ? and how to have the same gateway for a VM in the 2 sites in case we move a VM from a site to the other .
Thanks again
Hi Hythim ali.
overlay transport virtualization it will be done also with ASR see the link below :
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_otv/configuration/xe-16/wan-otv-xe-16-book/wan-otv-confg.html#GUID-95055197-6366-47EE-8EB8-C11C14272399
good luck
Rob B
The ISR4451 supports OTV with the AX license and would be cheaper than an ASR.
hi Rob,
Only we don't have ASR nor Nexus nor ISR
It is only a vpn provided by the service provider
So we have a router on each site connected to PE on provider site.
I think we'll go for L2TPV3 or ATOM in case point to point or VPLS in case of point to multipoint
I see it provide vlan extend to remote site and to be on the same broadcast domain
My question now what is the scenario will go when I  move a VM from HQ to a remote site. How it'll find the same gateway on the new site ?
And do you see all these alternate solutions will be configured by the service provider side only and we won't have any new configuration on our devices ?
