External IP not pingable from outside
Hi guys,
We have a cisco 2811 router with 2 ADSL interfaces. One dialer interface is used for internet and another dialer interface is used for VPN.
The dialer interface that is used for internet purpose is "Dialer 1" and the VPN is "Dialer 2".
The route looks like this:
ip route 0.0.0.0 0.0.0.0 dialer 1
Basically, I am able to the ping the external IP address associated with the Dialer 1 interface, however, I cannot ping the external IP address associated with Dialer 2.
Any thoughts? I am stuck with this for quite some time now.
Kind Regards,
Vignesh.
Kind Regards, Vignesh.
5 Replies 5
Richard Burts
Vignesh
My guess is that you get an assymetric path when the router is responding to ping to dialer 2. The packet arrived on dialer 2 but the default route is sending the response out dialer 1.
My suggestion of how to fix this would start with configuring Local Policy Based Routing. This is similar to Policy Based Routing but where PBR is for traffic that is transit going through the router the Local version is for traffic that is originated by the router. Local PBR uses the same kind of route map to identify the traffic and a set ip next-hop to send the traffic out a specified interface. But rather than being assigned to an interface it is configured in global configuration mode using this command
ip local policy route-map map-tag
You can check this link for more information
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1001002
Rick
Rick
Leo Laohoo
Hi Leo,
Well.. The local PBR did not work. Here is the config:
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 4
interface ATM0/1/0
no ip address
interface ATM0/1/0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 3
interface Dialer0
no ip address
interface Dialer3
description "Telstra connection"
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 3
dialer-group 3
ppp authentication pap callin
  ppp pap sent-username xxx@direct.telstra.net password 7 xxx
interface Dialer4
description "iiNET connection"
bandwidth 1319
ip mtu 1452
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 4
dialer-group 4
ppp pap sent-username xxx@iinet.net.au password 7 xxx
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip nat inside
no ip route-cache cef
ip tcp adjust-mss 1412
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map nonat interface Dialer3 overload
ip route 0.0.0.0 0.0.0.0 Dialer3
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
route-map nonat permit 10
match ip address 120
Kind Regards,
Vignesh.
I do not see any local PBR configuration. And the only nat that I see is for dialer 3. What would happen if you try to send data out dialer 4? There is not any translation configured for that traffic.
Rick
Rick
Hi Richard,
I have enabled local pbr on the router. The configuration for PBR:
ip local policy route-map LocalPBR
route-map LocalPBR permit 10
set interface Dialer4 Dialer3
I haven't enabled NAT on the Dialer 4 interface as it doesn't send out any traffic. This line is used to just receive email.
Kind Regards,
Vignesh.
