External IP to Internal IP NAT Issue
aanurast15
I have a 2600 I am trying to setup for educational use.
My Cable ISP has issued me 5 routable IP's through their SMC modem 86.28.12.226-229.  The SMC modem is .225.  Currently the internal network can get out through .229 as expected but nothing outside (tcp 80 to web server) can get through.  When I assigned the ip's to e0/1 as secondarr I could get it to route from the inside network (so hitting .226 80 went to the correct place) but it still didn't work from the outside - plus I read that wasn't a great way to do it anyway.
After two days of reading through posts and discussion I am pretty sure this is going to be an easy answer and probably make me feel silly for asking.
interface FastEthernet0/0
description LAN Interface
ip address 192.168.0.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
description WAN Interface
ip address 86.28.12.229 255.255.255.248
ip nat outside
speed 100
full-duplex
interface Serial0/1
no ip address
shutdown
ip nat inside source list 100 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.0.150 80 86.28.12.228 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 86.28.12.225
no ip http server
no ip pim bidir-enable
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
Thanks in advance!
mfurnival
Level 4
Level 4
The config looks OK to me.
Can you try and hit the outside address on port 80 and do:
#show ip nat translations
#debug ip nat
and paste the output please?
mfurnival
Level 4
Level 4
#debug ip nat
Hello mfurnival,
I had the gateway set to the old ip on the VM the webserver os was hosted on.  That is what causing the grief.  I am giving you the credit because your confirmation of my config drove me into looking outside the router for the real issue.
Thank you for your help and quick response!
Cheers!
