Extreme high number of output drops.
marcelnjkoks
Hi, at a customers' site we have two 3845 routers connected via a (EVPN) 1Gb WAN connection (fiber).
Most high volume traffic is send from site A (office) to site B (datacenter).
On the A side router we see an extreme high number of output drops;
Total output drops: 473316545
40 seconds later:
Total output drops: 473321960
So rising very quickly.
The max throughput reached is about 380 Mbit/sec. Input interface speed from the LAN is also Gb (copper).
We suspect the two are related (much output drops, bad performance), but where to start troubleshooting?
Could do with some pointers, thanks!!
10 Replies 10
paolo bevilacqua
Can you please include the full "show interface" - for all the interfaces.
Sure:
Side a:
#show interfaces gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is PM-3387, address is 0022.55e6.9913 (bia 0022.55e6.9913)
  Description: LINE-ID V268575- ID 6467
  Internet address is 10.10.10.1/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 96/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:08, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 473316545
  Queueing strategy: fifo
  Output queue: 32/40 (size/max)
  5 minute input rate 8473000 bits/sec, 14941 packets/sec
  5 minute output rate 379344000 bits/sec, 31404 packets/sec
     849214129 packets input, 1155482862 bytes, 29 no buffer
     Received 226486 broadcasts, 0 runts, 0 giants, 1 throttles
     0 input errors, 4 CRC, 4 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 51856 pause input
     875497572 packets output, 3304958944 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     4 lost carrier, 0 no carrier, 434 pause output
Side B:
  Hardware is PM-3387, address is 0022.90a8.bb33 (bia 0022.90a8.bb33)
  Internet address is 10.10.10.2/30
     reliability 255/255, txload 2/255, rxload 97/255
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 10739
  Output queue: 0/40 (size/max)
  5 minute input rate 381081000 bits/sec, 31592 packets/sec
  5 minute output rate 8602000 bits/sec, 15138 packets/sec
     2413913293 packets input, 2051875065 bytes, 0 no buffer
     Received 604359 broadcasts, 1 runts, 0 giants, 0 throttles
     0 input errors, 9 CRC, 8 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 840 pause input
     3218155929 packets output, 1071013994 bytes, 0 underruns
     8 lost carrier, 0 no carrier, 254660 pause output
Can you please post ALL the interfaces for either sides or both.
The other two interfaces, facing the LAN:
A side:
show interfaces gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is BCM1125 Internal MAC, address is 0022.55e6.9911 (bia 0022.55e6.9911)
  Description: *** LAN ***
  Internet address is 172.25.253.3/24
  Keepalive not set
  Full-duplex, 1000Mb/s, media type is RJ45
  Output queue: 0/100 (size/max)
  30 second input rate 234000 bits/sec, 55 packets/sec
  30 second output rate 221000 bits/sec, 57 packets/sec
     1197472585 packets input, 2490897503 bytes, 0 no buffer
     Received 16605 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 7423595 multicast, 0 pause input
     2604090893 packets output, 729062081 bytes, 0 underruns
     1 output errors, 0 collisions, 1 interface resets
     1 lost carrier, 0 no carrier, 0 pause output
B side:
  Hardware is BCM1125 Internal MAC, address is 0022.90a8.bb31 (bia 0022.90a8.bb31)
  Internet address is 172.26.250.20/16
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive not set
  Last input 00:00:09, output 00:00:00, output hang never
  5 minute input rate 533000 bits/sec, 638 packets/sec
  5 minute output rate 15547000 bits/sec, 1307 packets/sec
     381530928 packets input, 3569410611 bytes, 0 no buffer
     Received 6558886 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 20221909 multicast, 0 pause input
     1648728082 packets output, 1502180012 bytes, 0 underruns
     266 unknown protocol drops
You can try increasing hold queue, but output drops are not normal because with a single input interface of the same speed, the output interface cannot (in thoery) experience congestion. If itdoes, it means input packets are clumped and delayed somehow.
I would look at updating IOS and optimizing the configuration.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I agree with Paolo, that in theory, if you only have to active ports (of the same "speed"), you shouldn't be able to congest on egress.
Looking at your original "WAN" interface stats, I see "pause" counter has been incrementing.  I'm wondering whether your EPVN has been pausing your egress, which if your interface accepts, might answer Paolo's "delayed somehow."
If flow control is creating transient congestion, increasing hold queue might be one method to mitigate.  The other is to determine whether flow control is really necessary, and if not, disable it.
Disclaimer
Posting
I'm surprised you don't have more problems trying to support full gig on a 3845.
That aside, the default queue limit of 40 is often too shallow for gig.
As to why you're dropping, notice your int stats for g0/0/0 caught the egress queue at 32.
For gig, you might try a queue limit of 512.
PS:
A different question is why you're queuing at all.  You only have single gig port in and out of 3845?
Actually no, Gig 0/1 is the LAN interface, G0/0/0 is connected to the WAN service. Nothing else is connected to it, dedicated router.
Gig 0/1 show interface output is eing retrieved now.
How would i change the queue limit? Don't have much experience with this configuration.
Do you do that with the hold queue command?
Disclaimer
Posting
Yes.
marcelnjkoks
Hi, we have found the cause of the issue.
Raising buffers of turning of flow control did not change anything.
However, we have found why there was such a limitation.
We were using the build in Gb interface for LAN and a HWIC card for the WAN connection. After realising this it triggered us to search for issues with HWIC and found this:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8016a953.html
Q.
What is the maximum throughput of the four onboard HWIC slots?
A. The maximum throughput per slot is up to 400 Mbps full duplex. The new Gigabit Ethernet HWIC and the 4- and 9-port Cisco EtherSwitch HWIC modules are able to take advantage of this performance improvement up to the switching capabilities of individual platforms.
We did some reshuffling of the interfaces and were able to use the two build-in Gb interfaces, reconfigured, and the throughput is now just over 800Mb/sec, perfectly acceptable.
Just to let you know.
