Facing issue with 2611 after flash is removed
imranraheel
"""Hi;
After I erased my flash i reboot the Router 2611 and tried to Install new IOS from Xmodem (Console) and when I changed the Baud Rate to 115200 and restarted . Hyper Terminal does not display any thing ...Urgent"""
Richard Burts
Imran has posted this same question in the LAN Switching and Routing forum where it has received several responses. I suggest that any further discussion be consolidated in the LAN forum.
Rick
Rick
rlcarden1
Did you configure a new HyperTerminal window for 115200 and reconnect to the 2611 router? If not, then the previous HyperTerminal window you were using was probably still configured for 9600 baud. Here's a reference link: http://www.cisco.com/warp/public/130/xmodem_generic.html
Goutam Sanyal
Level 4
Level 4
Imran, Are you able to Hyper Terminal with the default settings? If so, pls find the attach which will help you to install IOS via XModem. Thanks Goutam *Pls rate if it helps you.*
